Designer FAQ
How should I impose a WHERE clause in my object(s) in the universe?
Is there any way to set up a prompt that will allow a user to select one value, many values, or type ‘ALL’ for all values in a list?
Now that my LOV lets me use ALL for all values, how do I get the ALL in the list?
I’ve deleted a universe and I’m in a mess! What do I do now?
How do I migrate universes between repositories?
How do I create cascading or nested prompts?
What is an isolated join and how do I fix it?
How do I increase the number of items I can pick from a list of values?
How can I calculate the number of hours between two dates?
Why do all my date lists of values include time and can I get rid of the time portion?
What are stored procedures and how do I use them?
Is there some automated way to populate descriptions for my universe objects?
How do I link universes? Why would I link universes? What are the restrictions? What are the advantages and disadvantages?
What is a fan trap, why is it a problem, and how do I resolve it?
What is a chasm trap, why is it a problem, and how do I resolve it?
How can I implement row level security?
What functions are included in the Functions list, and can I add more if I want to?
How can I select a table based on the response to a prompt?
Should I use Contexts or Aliases to resolve my loops?
How can I use the system date in a prompt or an object? Why won’t they parse?
I have a universe and it tells me it’s from a different CMS. How can I open it?
Bob (BOB member since 2002-06-06)
Log into Designer, using the Key of the repository that currently contains the universe.
(BOB member since 2002-08-08)
