Document a universe using Excel and the Designer SDK
Author: Dwayne Hoffpauir, EDS Corporation
Notes: The attached utility uses Excel and the Designer SDK to document a universe. Usage is rather straightforward. Click the “Document a Universe” button on the Control Sheet, log in, and select the specific universe. Information will be recorded on separate worksheets for:[list]Database tables
Database columns
Joins
Contexts
Classes
Objects
Conditions[/list]
[Moderator Edit: Added BI4 Download Link in this post - Dave Rathbun]
Document a Universe (XIr2).xls (95.0 KB)
Document a Universe (v6.5).xls (106.0 KB)
Document a Universe (v5.1).xls (106.0 KB)
Hi Dwayne Hoffpauir,
Thanks for the spreadsheet.
When I try to execute the attached spreadsheet, I am getting the error
"Run-Time Error ‘91’ "
Cannot Get Mother CLass
Is there any remedy for the same.
Kaustubh_1234 (BOB member since 2008-03-25)
Hmmm … that error happens when trying to find the .Rootclass property for a class that is already at the top level. The code is supposed to trap that error and be able to continue. Any chance that you’ve tweaked the code, and possibly disabled the error handling? Does it happen if you download a clean copy? Be sure you are using the correct version of the utility as well. If that doesn’t fix it, I may have to ask you to send me a copy of the universe causing the problem.
Hi Dwayne,
I have downloaded a clean copy and try to execute the same.
I am still having the same issue.
Kaustubh:
Are you using the correct Library of BO version. (I mean in the Tools–>Reference) ?
And I get the error:
“Compile error: Can’t find project or Library”
with this part of code highlighted:
Sub ListTables(Tbls As Designer.Tables)
Any Ideas please:
brawn
brawnbrawn (BOB member since 2008-03-05)
Do you see this function ‘ListTables’ exists in the code… when you go down in script window ?
Yes, I saw that sub() has been used couple of times in Dwayne’s code.
I get this error when i try to run all the version(Xir2, 6.5 and 5). . Is anything wrong on my PC? or is it for everybody.Any ideas dwayne
Brawn
Try going into the vba editor of Excel, then under ‘tools…references’ ,make sure you have checked ‘Business Objects Designer Library’. Then try running it. I hope this helps.
Chris_K :us: (BOB member since 2003-01-10)
Hi Dwayne,
Do you also have a similar macro which can be used to document a report.
Manish
manishdarak (BOB member since 2006-03-29)
For universe objects, try this … List objects used in a series of reports
To document more about a report, look here … http://lyontechnologies.com/free_stuff.htm … for the documentation add-in.
When i tried to Document a universe.
i am getting the following error
Failure in ListObjects()
VBAProject- -2147417851: Automation error
The server threw an exception.
universe version : XIR2
Can any one please help me in this ?
Ramprasad (BOB member since 2008-01-25)
Any chance that the description on an object is extremely long … like more than 1,024 characters?
Try changing the line of code that says this…
Rng(RowNum, 4) = Obj.Description
… to this
Rng(RowNum, 4) = Left(Obj.Description, 1024)
what do the following mean in the documenting excel in Objects tab:
Security Access Level(0)/Can be used Result(True/False)/Can be used Condition(True/False)/Can be used sort(True/False)/Show(True/False)
Shruti
shruthi (BOB member since 2008-02-25)
All of those are various properties of the object as set up in the universe. If you open a universe and look at the properties tabs (there are several) you should be able to figure it out. :slight_smile:
Thanks for your reply.
I changed the Macro code,still i am getting the same error.
Ram
I can only suggest that you step through the code, and report back exactly which object, property, and value is causing the problem. I may be able to offer a solution with that information.
Dwayne,
I used the download for 6.5 and it worked great for the first universe I tried. But when I run it against a much larger universe, it gives me a "Failure in ListObjects(): “VBAProject 7 - out of memory” error. Do you know of a way to get around this? Does it mean physical memory on my PC (it is rather old).
Thank you so much, Linda
lindacaron :us: (BOB member since 2002-07-16)
I get the error:
For this how can i include the business objects library ?
Adv. Thanks
Raghu
rpothineni :india: (BOB member since 2008-01-02)
Might the discussion here explain it?
