SAP BO 4.0 Universe and Report Documentation
Is there any automaticn toll to document SAP BO 4.0 UNIVERSE and Reprots. If it is there please let me know the path/way/download components/. It is very urgent for me please.
Like what this i am expecting
Notes: uses Excel and the Designer SDK to document a universe. Usage is rather straightforward. Click the “Document a Universe” button on the Control Sheet, log in, and select the specific universe. Information will be recorded on separate worksheets for:
Database tables
Database columns
Joins
Contexts
Classes
Objects
Conditions
or
or
The above mentioned URL are pointing to XI R2, 5.0.6.0 versions not belongs to BO 4.0.
Just for the purpose of clear understanding of my quesiton i have given there.
Thanks in advance,
bigboss (BOB member since 2011-03-04)
[Moderator Note: Moved from WebIntelligence XI to General Discussion]
Do you have any updates on this? I’m trying to document the 4.1 universe as well. Thanks!
moons :us: (BOB member since 2007-11-08)
do you have any update on Universe/IDT documentation tool availability for SAP BO 4.x.
haisri (BOB member since 2007-08-01)
As far as I saw SAP AGAIN dropped the ball or made it hard to work in and with a great BI tool…
You cannot use any previous automated script that documents an UNX universe.
SAP made it so Macros cannot work with it and you are stuck with guessing or painstakingly documenting the universes an object at a time.
That’s why we are NEVER using IDT… not worth it!
Joealyche (BOB member since 2012-02-29)
