Author: Business Objects
The ManagerO universe is used to report against the repository tables. Note that this version is for an Oracle-based repository. The repository documentation is a series of HTML files, listing and describing each of the repository tables. These files are the same files distributed in the freeware directory of the version 5 installation disk(s).
Author Notes:
Business Objects Freeware End-User License Agreement
This is a contract, between you and Business Objects S.A. BY INSTALLING, COPYING OR OTHERWISE USING THIS SOFTWARE, YOU AGREE TO BE BOUND BY ALL THE TERMS AND CONDITIONS OF THIS AGREEMENT. Please read it carefully.
This Agreement is for the Bridge product and related explanatory materials (“Software”). The term “Software” also includes any upgrades, modified versions, or updates of the Software licensed to you by Business Objects, if and when available.
Business Objects grants to you a nonexclusive license to use the Software, provided that you agree to the following:
Use of the Software. You may install the Software on a hard disk or other storage device; install and use the Software on a file server for use on a network for the purposes of (i) permanent installation onto hard disks or other storage devices or (ii) use of the Software over such network; and make backup copies of the Software. You may make and distribute unlimited copies of the Software, including copies for commercial distribution, as long as each copy that you make and distribute contains this Agreement, and the same copyright and other proprietary notices pertaining to this Software that appear in the
Software.
No Support. Business Objects is under no obligation to provide support or maintenance if any problems are encountered with the Software.
Warranty disclaimer and limitation of liability. The Software is being delivered to you AS IS, and the use of the Software is at your sole risk. BUSINESS OBJECTS AND ITS SUPPLIERS HEREBY EXPRESSLY DISCLAIM ALL WARRANTIES AND CONDITIONS EITHER EXPRESS OR IMPLIED INCLUDING BUT NOT LIMITED TO THE IMPLIED WARRANTIES OR CONDITIONS OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. BUSINESS OBJECTS AND ITS SUPPLIERS DO NOT WARRANT THE PERFORMANCE OR RESULTS YOU MAY OBTAIN BY USING THE SOFTWARE OR DOCUMENTATION. BUSINESS OBJECTS AND ITS SUPPLIERS MAKE NO WARRANTIES, EXPRESS OR IMPLIED, AS TO NONINFRINGEMENT OF THIRD-PARTY RIGHTS, IN NO EVENT WILL BUSINESS OBJECTS OR ITS SUPPLIERS BE LIABLE TO YOU FOR ANY CONSEQUENTIAL, INCIDENTAL, OR SPECIAL DAMAGES, INCLUDING ANY LOST PROFITS OR LOST SAVINGS, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGES, OR FOR ANY CLAIM BY ANY THIRD PARTY.
General Provisions. This Agreement is subject to the laws of France. This Agreement will not be governed by the United Nations Convention on Contracts for the International Sale of Goods, the application of which is expressly excluded. If any part of this Agreement is found void and unenforceable, it will not affect the validity of the balance of the Agreement, which shall remain valid and enforceable according to its terms. This Agreement shall automatically terminate upon failure by you to comply with its terms. This Agreement may only be modified in writing signed by an authorized officer of Business Objects.
Copyright (c) Business Objects 1996,1997,1998,1999,2000. All rights reserved.
RepositoryDoco.zip (85.0 KB)
managero.zip (12.0 KB)
BOB Downloads (BOB member since 2003-05-05)
system
July 7, 2005, 12:36pm
2
As a convenience to our members, the repository reference from the “Freeware” folder on the BusinessObjects cdrom has been loaded on BOB’s server.
Repository Reference for 5.1.x
Bob (BOB member since 2002-06-06)
system
June 30, 2010, 1:17pm
3
Hello BO guru!
Is there a similar download for the repository for BO XI 3.1?
I found a Query Builder helper…but it would be great if i can write queries as a freehand SQL and put that onto a report to track some of the key auditor/CMS activity.
Thanks so much
Avinash
avinash.phenom (BOB member since 2010-06-07)
Have a look to the BOBdownload’s area you can find useful solution covering your need…
system
January 30, 2013, 10:27am
5
when i testing connection universe am getting below eror.
DBD: ORA-12154: TNS:could not resolve service name
Please guide me how can i parse my connction to use this manger universe
BOXi3.1 and oracle
pavan.au143 (BOB member since 2011-12-29)
system
January 30, 2013, 11:56am
6
Hi Pavan -
The Business Objects repository database cannot be queried for version XIR2, XI3 and BI4 using this download link.
The new CMS repository is accessibly only (officially) via specialized APIs; we’ve built a similar driver/universe layer for XI3 and BI4 for folks like yourself; visit our site and you’ll find the download link there.
Hope this helps -
Atul
system
January 30, 2013, 1:40pm
7
Thanks for your reply.,
Could you please provide me link were i can get the smiliar onwe you have mentioned in your post.
system
January 30, 2013, 1:56pm
8
You can find it at:
system
January 30, 2013, 2:27pm
9
there were 3 topics are there under download which one do i need to download and alos am seeing erorr.its asking email ids and some informationn can you pleae upload here ?? or send it to me pavan.au143@gmail.com
