Code samples and other downloads are posted as examples only. Be smart: be sure to understand the code before you use it in a production system. bobj-board.org is not responsible for maintaining or validating the code samples or other downloads found here, and makes no representation as to fitness for any particular purpose. Use at your own risk.
How do I get my code posted?
Post your code in the downloads category. Please include the following information with your post:
Author: (preferably including contact information)
Author notes: use the Quote formatting to highlight
Platform: If appropriate
Version: If updates are available
Code: use the Code formatting to highlight
What if the code is rather lengthy, is an add-in, includes a VBA form, etc? What if the “downloadable” is a SQL script, sample universe, or other “non code sample” item?
Same as above. Post the information using the attachment feature in downloads.
After review, the final code or downloads will be copied into this area by a board moderator.
How can I ask a question about a downloadable item?
Registered users should be able to reply to existing topics in this forum to ask the author a specific question. Users cannot start new topics in this forum; if you have something to submit please follow the instructions as provided.
What level of support is offered for these items?
It is completely up to the author of the item.
BOB Downloads (BOB member since 2003-05-05)
