I’ve installed designer and other client tools on a machine outside firewall. Does anybody know what needs to be done to allow for successful logon…ports, etc.
I’m able to remote desktop to the BO Server by using the external IP address.
From inside the firewall I cannot logon while using the external IP as the System name, but it works using the interal IP address.
For designer
I think it is just the CMS and the IFRS and OFRS.(for importing and exporting to the repository and logging on.(u know to use -port and -requestport to lock down the ports these run on, otherwise they just choose random ports on start up, see manual as advised above)
If using designer, the user will also need a connection to the database the universe is built on, so remember those ports.
The user could also use designer in standalone mode(still DB connection will be required though).
