Author: Ryan Gordon
Author Notes:
Platform: All
Version: 1.0
Code: See jar file
access_level_rights.zip (14.0 KB)
BoB LoblaW
(BOB member since 2007-10-23)
Author: Ryan Gordon
Author Notes:
Platform: All
Version: 1.0
Code: See jar file
BoB LoblaW
Moderator note:
Approved, and moved to BOBâs Downloads.
And thanks for sharing.
I like your signature ![]()
Marek Chladny
(BOB member since 2003-11-27)
I am getting this error:âThe specified JVM âC:\PROGRA~2\Java\jre6\bin\bin\java.exeâ does not exist or is not a valid executable file.â
I entered the correct patch in tje âClasspath:â when scheduling the program object and then I got this error: âThe working directory âE:\rights.csvâ could not be found.â
Do I need to setup a JAVA_HOME variable to point to the correct JVM location? Does the administrator user need to have write access over the working folder?
Thanks for sharing and any feedback is appreciated.
rbrito
(BOB member since 2007-09-06)
The path listed in that error message has one too many âbinâ directories listed. I think the correct path should be C:\PROGRA~2\Java\jre6\bin\java.exe.
Yes, JAVA_HOME should point to the root folder of your Java installation. For example, c:\program files\Java\jre6 (note that you donât point to the âbinâ folder).
When BOE runs a Java program object, you have to specify credentials for a valid BOE user such as administrator. However, when this program tries to write the output to e:\ in this case, it uses the ID that runs the program job server. So your (Windows) service account needs to have rights to e:\ to avoid that error.
BoB LoblaW
This sounds like a great tool, i have followed the instructions on putting this in the CMC however i am getting an error when trying to run or schedule.
Failed to load class: [com.forumtopics.bob.RightsLister]. Reason: [java.lang.ClassNotFoundException: com.forumtopics.bob.RightsLister].
Can anyone advise why i am getting this issue?
pyperg (BOB member since 2008-12-31)
Not sure what would cause the class to fail to load. Can you run it from a command window?
BoB LoblaW
First of all thank you for presenting this solution. I am trynig to get this working but I cant figure out why its not working.
System settings:
BI4.0 Feature pack 3 patch 3
Java 6 update 19
What I did:
When I Schedule this program file it says that its failing with the message:
âError Message:Could not access a directory required to run the program.â
When i specify a working directory without a output file like:
Exception in thread âmainâ java.lang.IllegalArgumentException: An output file name was not specified. ExitingâŠ
at com.forumtopics.bob.RightsLister.checkParams(RightsLister.java:85)
at com.forumtopics.bob.RightsLister.run(RightsLister.java:74)
at com.crystaldecisions.sdk.plugin.desktop.program.internal.ProgramWrapper.main(ProgramWrapper.java:174)
I also tried the Command line but this it returning me with the message. Cound not find the main class: com.forumtopics.bob.RightsLister. Program will exit. Example of my command line code:
java.exe -cp âC:\Users\Michel\Desktop\access_level_rights;.â com.forumtopics.bob.RightsLister Michel XXXXXX ZEW-V-913BC091 secEnterprise C:\Users\Michel\Desktop\access_level_rights\rights.csv
or just
But even then its giving me the same message. âCould nog find main CassâŠâ
I Hope this is sufficient information. Can you help me out?
Thank you
micheljeweetwel (BOB member since 2010-10-18)
micheljeweetwel,
When running the object in InfoView/CMC, the file name is specified in the âProgram Parametersâ field when scheduling. This is normally where you enter prompt values if scheduling a report. I would post a screenshot, but it looks like I canât do so in the downloads forum??
If you are running from a command line, the path to the BOE .jar files have to be included in your classpath. So instead of this:
java.exe -cp "C:\Users\Michel\Desktop\access_level_rights;." com.forumtopics.bob.RightsLister Michel XXXXXX ZEW-V-913BC091 secEnterprise C:\Users\Michel\Desktop\access_level_rights\rights.csv
use this:
java.exe -cp "C:\Users\Michel\Desktop\access_level_rights;.;C:\Program Files\Business Objects\common\4.0\java\lib\*" com.forumtopics.bob.RightsLister Michel XXXXXX ZEW-V-913BC091 secEnterprise C:\Users\Michel\Desktop\access_level_rights\rights.csv
Hope that helps.
BoB LoblaW
Hi BoB LoblaW,
Works like a charm !!! thank you for this tool. I was looking at the output and i can see that this lists all the objects which are granted to an Access Level. Is it also possible to see the full list (Unassigned, Granted and Assigned)? Within the CMC you can do that by selecting the common filter setting to âNo filtersâ. This is probably an enhancment on your current version. The reason why i am asking this is because when your documenting your BI security environment and something changes, you dont have to do an extract every time and you have basically all the rights available documented in your output.
Again, many thanks.
Kind regards,
Michel
Good to hear. There was an issue, the details of which escape me at the moment, which prevented all the rights from being retrieved so I stopped pursuing that option. Also, the ever present time constraint reared its head. Regardless, I donât fully understand your reasoning behind this. If the rights in an access level change, wouldnât you want to run the program again to pick up the changes?
BoB LoblaW
Will this work for XIR2 version
billa (BOB member since 2008-06-11)
No, this wonât work with XI R2 because custom access levels were introduced in XI 3.1.
BoB LoblaW
Missed the part about renaming the zip to a jar. A few other clarifications for others:
The output path and filename goes in the Arguments field of the Program Parameters tab. Working directory and Classpath donât appear necessary in the CMC.
I suggest using .txt instead of .csv since itâs not comma-separated.
For the command line class path I had to add access_level_rights.jar, not just access_level_rights, or * instead. And the * is definitely necessary after the java lib directory as the newer example has.
craiggsmith (BOB member since 2009-06-01)
Thanks for the great SDK codeâŠ
[b]Further if you could help us with export of Groups, FoldersName along with Access Levels that would be greatâŠ
As we can solve our problem to export Folder Security for BO EnviromentâŠ
Looking for update on the post âŠ[/b]
Here is the more information on Scheduling this program as .csv format.
under Program Parameters enter fields as below.
under Program Logon:
enter the BO user/pass: (administrator user can be used)
Jatinder Bhatti
Jatinder Bhatti (BOB member since 2016-03-04)
No files show, even after schedule run is successful. Checked many times, with all the attempts listed here. Tried the command prompt, but the C:/Business Objects/Common directory does not exist with 4.2 Any ideas?
sapaa (BOB member since 2014-02-21)
I created a folder at the root level of my C drive called RightsLister for ease of access, added the jar file to it, and use the following batch file. Note that it only returns custom levels, so if you want to see the rights for standard levels you have to copy them. There are a few rights that come back as Unknown right in 4.2; most are related to new features such as BI commentary or send to SFTP, but some I could not find a match for. There is even one right that displays as Unknown right in the CMC!
@echo off
set /p server=server:
set /p username=username:
set /p password=password:
cls
java.exe -cp âC:\RightsLister*;C:\Program Files (x86)\SAP BusinessObjects\SAP BusinessObjects Enterprise XI 4.0\java\lib*â com.forumtopics.bob.RightsLister %username% %password% %server%.csw.l-3com.com secEnterprise C:\RightsLister\access_level_rights_%server%.txt
start ââ /b âC:\Program Files (x86)\Microsoft Office\Office14\excel.exeâ C:\RightsLister\access_level_rights_%server%.txt
got it to work!!! with some modifications on your batch!!!
You can access those info from QueryBuilder.
But yes, its output is ⊠[b]difficult to export
or isnât it ? [/b]
BICLEVER ( dot com ) offers a FREE tool ( .exe, sorry, for windows ) that is called âCMSquerybuilderâ
It accepts exactly the same queries that you put in QueryBuilder, but has an option to âexport to excelâ
Seems to work now with 4.2 (client tools installed) and MS Office 64bit
And I guess there will be a âthanksâ from me too.
Now trying to get this to work, looks very promising.
RensH
(BOB member since 2007-06-18)
