I want to query BO dB repository like Microsoft Reporting Services.
I now BO repository has encrypted binary data. Maybe there is a way to do that.
Does anybody know?
bo_rapor (BOB member since 2009-01-03)
Does anybody know?
Sorry but you can’t query repository as it was in v4/5/6. A solution is to use the query builder tool but results are not very exploitable. So the solution is to use SDK to achieve it…
bernard timbal (BOB member since 2003-05-26)
Then, is only way sdk?
Yes, only sdk if you considere (like me) that Query Builder is not useable
Did you try the security viewer?
how can i reach security viewer?
is it a tool or is it in BOXIR3.0?
No sorry only for Xir2 …
Hi, I managed to work out how to decrypt the infoobjects table.
For Oracle you could use the following to build a universe but run it at your own risk. I have only used it against test and development environments just in case it causes and issue. Also, I wouldn’t rely on it working when upgrading Webi.
select
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
translate(replace(objname,‘BE’,’.’),’)±/13579;=?ACEGIKMOQSUWY]!"{’,‘ABCDEFGHIJKLMNOPQRSTUVWXYZ’),
‘|>','1'), '
|@’,‘2’),
‘|B','3'), '
|D’,‘4’),
‘|F','5'), '
|H’,‘6’),
‘|J','7'), '
|L’,‘8’),
‘|N','9'), 'M|N','_'), 'M|Z','-'), '@',' '), '
|<’,‘0’),
‘B~P’,’/’),
‘M}Z’,’:’),
‘B|C’,’(’),
‘B|D’,’)’),
‘B~K’,’@’)
trans,cms.objname,cms.si_cuid,
cms.parentid,
decode((select typeid from CMS_INFOOBJECTS5 cmsp where cmsp.objectid = cms.parentid),311,‘Webi Report’,308,‘Deski’,1,‘Folder’,(select typeid from CMS_INFOOBJECTS5 cmsp where cmsp.objectid = cms.parentid)) parent_typeid,
cms.objectid,to_date(substr(cms.lastmodifytime,1,19),‘YYYY MM DD HH24 MI SS’)+1/24 lastmodifytime
,decode(typeid,311,‘Webi Report’,308,‘Deski’,1,‘Folder’,typeid) typeid
It’s not complete but should bring back something useful
For SQL Server try
select
objectid,
parentid,
ownerid,
lastmodifytime,
upper(left(objectname,len(objectname)-2)) ObjectName,
typeid,
type,
si_cuid
from
SELECT
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
cast(objname as varchar(2000))
,‘S’,‘v’)
,‘M’,‘s’)
,‘A’,‘m’)
,’)’,‘a’)
,’+’,‘b’)
,‘C’,‘n’)
,’-’,‘c’)
,’/’,‘d’)
,‘O’,‘t’)
,‘E’,‘o’)
,‘1’,‘e’)
,‘3’,‘f’)
,‘G’,‘p’)
,‘5’,‘g’)
,‘7’,‘h’)
,‘W’,‘x’)
,‘U’,‘w’)
,‘Q’,‘u’)
,‘I’,‘q’)
,‘9’,‘i’)
,’:’,‘i’)
,’;’,‘j’)
,‘K’,‘r’)
,’=’,‘k’)
,’?’,‘l’)
,’[’,‘y’)
,’]’,‘z’)
,‘B~S’,’&’)
,’!BO’,’.’)
,‘B|C"’,’(’)
,’!B|D’,’)’)
,‘M|Z’,’-’)
,‘M}L’,’,’)
,‘M|N’,’_’)
,‘M}Z’,’:’)
,’!B{B’,’’’’)
,’|<','0') ,'
|>’,‘1’)
,’|@','2') ,'
|B’,‘3’)
,’|D','4') ,'
|F’,‘5’)
,’|H','6') ,'
|J’,‘7’)
,’|L','8') ,'
|N’,‘9’)
ObjectName,
case
when TypeID = 262 then ‘Webi Report’
when TypeID = 314 then ‘Deski Report’
when TypeID = 283 then ‘PDF’
when TypeID = 267 then ‘Text’
when TypeID = 323 then ‘Excel’
when TypeID = 266 then ‘Universe’
when TypeID = 278 then ‘Publication’
when TypeID = 299 then ‘Connection’
when TypeID = 19 then ‘User type 19’
when TypeID = 18 then ‘User type 18’
when TypeID = 47 then ‘User type 47’
when TypeID = 48 then ‘User type 48’
when TypeID = 8 then ‘Shortcut’
when TypeID = 1 then ‘Folder’
when TypeID = 20 then ‘Groups’
when TypeID = 13 then ‘Server’
when TypeID = 16 then ‘BO Server’
when TypeID = 21 then ‘Event’
when TypeID = 24 then ‘License Key’
else ‘Other’
end Type,
FROM [BOXI_CMS].[dbo].[CMS_InfoObjects5]
) BORepository
Cheers
marklee (BOB member since 2008-12-12)
YOU ARE A GOD!!!
sticky (BOB member since 2007-04-20)
waow. thnx.
this is also desert;
replace(convert(char(10),lastmodifytime),’ ‘,’’) as lastmodifytime,
hi,
thank you for your help. I want to add folder descriptions in my report.
do you column name of that?
do you have any idea about logging description of objects?
And also;
We are using nt authentication for bo. How can we report nt group names in our audit report?
Thnx
And one more question:
We can find universes with TypeID = 324, and groups with TypeID = 20.
How can we releate Universes with Groups?
This means; we want to say “x” group has right for “b” and “c” universes.
Is it possible?
Hey,
1st of all, thank you so for this code correction. I was going nuts with the code from businessobjectstips.com where the commenter missed the ‘0’ (zero replacement).
I have a question.
What is the TYPEID for Crystal Reports?
Is it 2?
I seemed to get the parameter objects related to Crystal Reports when I restrict by TypeID 2 only.
exile (BOB member since 2008-05-03)
It looks like for SI_Kind =‘CrystalReport’ the TYPEID/SI_OBTYPE is 2 but please verify
bdharma (BOB member since 2008-07-07)
That would be great!
Cybersoft (BOB member since 2007-12-08)
hi,
that work is awesome, was wondering and trying to understand how did you manage to decode the characters, is there a way or pattern you have…
how did you match the characters with Letters/Numbers?
appreciate if you could help me out here…really appreciate…
thanks,
-wasy
wasy.wasu (BOB member since 2006-09-18)
Does anyone has an updated decryption logic or character match table for BO 4.0 and BO 4.1?
The included query runs against my BO 4.0 CMS database but is not correctly showing all the object names.
ErikR (BOB member since 2007-01-10)
i was able to change few of them and this is working fine for me…i can see all of the names properly.
SELECT
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
replace(
to_char(objname)
,’)’,‘a’)
,’+’,‘b’)
,’-’,‘c’)
,’/’,‘d’)
,‘1’,‘e’)
,‘3’,‘f’)
,‘5’,‘g’)
,‘7’,‘h’)
,‘9’,‘i’)
,’:’,‘i’)
,’;’,‘j’)
,’=’,‘k’)
,’?’,‘l’)
,‘A’,‘m’)
,‘C’,‘n’)
,‘E’,‘o’)
,‘G’,‘p’)
,‘I’,‘q’)
,‘K’,‘r’)
,‘M’,‘s’)
,‘O’,‘t’)
,‘Q’,‘u’)
,‘S’,‘v’)
,‘U’,‘w’)
,‘W’,‘x’)
,’[’,‘y’)
,‘Y’,‘y’)
,’]’,‘z’)
,’|<',0) ,'
|>’,1)
,’|'||'@',2) ,'
|’||‘B’,3)
,’|'||'D',4) ,'
|’||‘F’,5)
,’|'||'H',6) ,'
|’||‘J’,7)
,’|'||'L',8) ,'
|’||‘N’,9)
,‘Bo’,’.’)
,‘m}d’,’–’)
,‘m}l’,’,’)
,‘m}w’,’;’)
,‘m}z’,’:’)
,‘o}H’,’+’)
,’!m|N’,’’)
,‘m|N’,’’)
,‘m~T’,’?’)
,‘B|c’,’(’)
,’!B|d’,’)’)
,‘m|Z’,’-’)
,‘B|e’,’[’)
,‘B|’,’]’)
,‘B~s’,’&’)
,‘B~w’,’%’)
,‘B~v’,’#’)
,‘B~p’,’’)
,‘o~&’,’~’)
,‘m~L’,’!’)
,’!B{B’,’’)
Object_name,
also, these are the types i was able to identify for my use.
case
when TypeID = 1 then ‘Folders’
when TypeID = 16 then ‘BO Servers Nodes’
when TypeID = 18 then ‘Favorites Folders’
when TypeID = 19 then ‘users’
when TypeID = 20 then ‘groups’
when TypeID = 22 then ‘Calendars’
when TypeID = 45 then ‘Categories’
when TypeID = 47 then ‘Personnal Categories’
when TypeID = 48 then ‘inboxes’
when TypeID = 57 then ‘Access Levels’
when TypeID = 59 then ‘Clusters’
when TypeID = 260 then ‘PDF Instances’
when TypeID = 266 then ‘Excel Report’
when TypeID = 268 then ‘Profiles’
when TypeID = 273 then ‘Relication list’
when TypeID = 275 then ‘Universes’
when TypeID = 291 then ‘Federation Jobs’
when TypeID = 291 then ‘Replication Jobs’
when TypeID = 295 then ‘Remote Connections (Federation)’
when TypeID = 319 then ‘Webi report’
when TypeID = 322 then ‘LCM Jobs’
when TypeID = 333 then ‘Probes’
when TypeID = 342 then ‘Universes (.unx)’
when TypeID = 363 then ‘Connections’
when TypeID = 365 then ‘Events’
when TypeID = 392 then ‘Platform Search Scheduling’
else ‘Null’
end object_type,
hope this helps…
let me know.
-wasy
