I solved the installation problem by not going to the control panel but to the local directory from where I had ran setup to install Data Services but this time I ensured that I kicked off the setup program with “Run as Administrator”.
After selecting “Modify” the installer would let me select the Cleaning Package option.
However, after installation I noticed that I still could not select any output columns from the Data Cleanse transform. Clearly something was still not right.
I ensured that the firewall was turned off to prevent any issues with ports etc. But still nothing.
But when I checked the installation log, I found this entry:
22:22:00.585 Error reading data deployment file(D:\Download\SAP\BODS 4.1 SP1\install\SAP_DATA_SERVICES_4.1_MULTIOS__DL__\DATA_UNITS\DS_41_WIN64\dunit\product.dataservices64-4.0-core-32\..\..\im.lac.ds.cpdata.cp-4.0-core-64\*\actions\data\PERSON_FIRM.txt).
Cannot find file: D:\Download\SAP\BODS 4.1 SP1\install\SAP_DATA_SERVICES_4.1_MULTIOS__DL__\DATA_UNITS\DS_41_WIN64\dunit\product.dataservices64-4.0-core-32\..\..\im.lac.ds.cpdata.cp-4.0-core-64\*\actions\data\PERSON_FIRM.txt
Fatal exception: Cannot find file: D:\Download\SAP\BODS 4.1 SP1\install\SAP_DATA_SERVICES_4.1_MULTIOS__DL__\DATA_UNITS\DS_41_WIN64\dunit\product.dataservices64-4.0-core-32\..\..\im.lac.ds.cpdata.cp-4.0-core-64\*\actions\data\PERSON_FIRM.txt
I put the PERSON_FIRM in the “im.lac.ds.cpdata.cp-4.0-core-64” directory under actions/data as the documentation told me to do so.
Does the above error make any sense to anybody???
UPDATE:
I completely uninstalled Data Services but left the config in place. I then reinstalled from the installer directory where I copied the PEOPLE_FIRM.ZIP into the right location.
Sure enough - I can now select the Cleansing Package as part of the installation. During the installation I point to the existing DSCONFIG and everything is up and running.
However, I still DO NOT get any output fields when dragging the Data Cleanse transform into the DF.
Also, when running the setup from Control Panel -> Programs and Features -> SAP Data Services 4.1 SP1 -> MODIFY … The Cleansing Package is unticked!!
So I’m now uninstalling Data Services again and this time I will wipe my DSCONFIG as well. Although I do have a feeling I’ll be having the same result .
I’m rapidly running out of ideas here though…
UPDATE 2: Ok, wiped the config, reinstalled Data Services and it didn’t make a darn difference.
Designer shows no output fields for the Data Cleanse transaction.
Also the Content Domain Sequence Option window shows no available values.
Forget good ideas… I’m open to any suggestion, good or bad, at this point. Or raise a SAP case?
ErikR
(BOB member since 2007-01-10)
