Genius Team - any luck for SAP BO BI 4 . I would like to extract the user details with group like as following
LogonID
Group
Sub Group
Description and etc
Looking forward the macros…
stsrin
(BOB member since 2005-07-21)
LogonID
Group
Sub Group
Description and etc
stsrin
Check if this utility for BO BI 4 can help you:
Marek Chladny
(BOB member since 2003-11-27)
thank you for your kind reply - there i couldnt extract user, group details and etc …
stsrin
Then I am not aware of any other such utility for BO BI 4.
Marek Chladny
Team - May I get the same kind of macro for SAP BO BI 4 - Looking forward to hear from you -
stsrin
I get a compile error when I try this tool. error:
Compile error. Cannot find project or library. When I look at the code. It shows Dim SessionManager, Sess As SessionMgr
Ram
Ram31 (BOB member since 2004-11-29)
Thank you Ram - I am facing same error …
stsrin
Hi Bo_Arale,
Could you please post the tool which is working for BO XI R3.
CK
Chandru 901
(BOB member since 2007-07-20)
Hello all BI4.x users,
I was able to extract BO Users and Groups lists using BI40 repository. Just FYI, we are currently on BI4.0 SP4, Patch 4.
I was trying to upload the new script for anyone who’s interested. But for some reason can’t do it with my profile. Let me know.
uploaded topic here:
Marek - can you grant me the privilege to upload the code?
-Fernand_DaCien
Los Angeles, CA
Fernand_DaCien
(BOB member since 2006-05-06)
It’s done:
Marek Chladny
It’s very usefull and works very well with XI 3.1 SP3.
Thank you very much
Ben
b_gonzalez
(BOB member since 2008-10-23)
Do we have anything useful for BO4?
dmitry.anoshin
(BOB member since 2013-03-28)
Nick Daniels
(BOB member since 2002-08-15)
Nick,
I run BOXI UserList V3, and got “Compile error: Can’t find project library”
How can i fix it?
dmitry.anoshin
Hi Julien. Thank you very much for the Excel macro, it’s proven very useful for mass user loads.
I’m wondering if there is a way to automate the process of adding users (members) to groups in the BOXI3.1 CMC. Could this functionality be added to the macro, or is this better left for a separate macro/thread?
Also, is there any way to extend the timeout limit when either extracting from or modifying to the repository?
Michael Rodriguez
michael.rodriguez (BOB member since 2013-05-02)
I am getting the following error when using this utility.
Run-time error ‘-2147417848 (80010108)’:
Automation error
The object invoked has disconnected from its clients.
Please suggest.
Sadiq.
sk_sadiq (BOB member since 2007-09-17)
Can this be used to get the user group list in BI 4.0 we have this new platform and I don’t see any Macro’s for this BI 4.0
bodiscussion (BOB member since 2010-07-11)
How can I make this utility work with Win AD authentication?
We have BO XIR3.1 SP4 with Win AD authentication?
When I try to connect with the utility, it is giving me connection error:
“Enterprise Authentication could not log you on. Please make sure your logon information is correct. (FWB 00008) 1000440.”
Any idea how to get it connected?
Thanks in advance.
izak004
(BOB member since 2010-11-10)
The same answer as I replied to you other question:
Open the utilitie’s VBA code and replace every occurence of
secEnterprise
with
secWinAD
That would be the easiest and fastest way.
Marek Chladny
Hi Marek,
Thank you for replying quickly.
Please excuse my ignorance for another doubt.
I have the ‘BOXI UserListV4’ version of the utility and when I open it, press ALT+F11, it opens VB for applications with one window with the following code
“Private Sub Workbook_SheetChange(ByVal Sh As Object, ByVal Target As Range)
If (Target.Row > 2 And Target.Column < 13) Then
Dim Rng As Excel.Range
Set Rng = Sheets(“Users”).Cells
For Each cell In Target
Rng(cell.Row, 13) = “1”
Next cell
End If
End Sub”
I looked into other options from the menu and on the right pane, but couldn’t understand where to change the code. Could you please guide me?
I was able to edit the code for the other utility but with error on some of the tabs, which I will ask/post later in that topic
Thanks again
izak004
