system
July 11, 2017, 2:37pm
1
I am getting below error message while installing Xcelsius BI4
I am using WINDOWS 10 Enterprise with Microsoft Office 2016 already installed on my system
MICROSOFT OFFICE EXCEL (XP OR HIGHER) MUST BE INSTALLED ON THE SYSTEM
bob2210 (BOB member since 2010-09-23)
system
July 11, 2017, 2:40pm
2
[Moderator Note: Moved from General Discussion to Other Products -> Xcelsius - Crystal Dashboard Design]
system
July 11, 2017, 4:57pm
3
Is windows 10 a supported OS for Xcelsius BI 4? I sure that Office 2016 is supported. Maybe BI 4.2 supports it. You need to check the PAM to see.
kevlray (BOB member since 2010-06-23)
system
July 11, 2017, 7:11pm
4
Can you please help provide PAM link?
system
July 11, 2017, 7:51pm
5
Here is a link for BI 4.1. I found a link for BI 4.2, but it requires a login. Also a quick look and Office 2016 is supported for BI 4.2 SP3.
https://www.sap.com/documents/2016/05/e23d0b85-737c-0010-82c7-eda71af511fa.html
system
July 13, 2017, 7:54am
6
If it helps, I’m using 4.1 client tools, inc SAP Business Objects Dashboards (aka xcelsius) on Windows 10, with Office 2010 with no issues.
Debbie
Debbie (BOB member since 2005-03-01)
system
August 3, 2017, 4:10pm
7
I recently moved from a Windows 7 machine to Windows 10 and when installing Xcelsius 4.1 SP 7, I had to revert to Office 2013 to get through the installation process.
Supposedly, there are workarounds that can get you through the installation such as creating dummy excel files then using later office versions, but I had no luck with any of them.
When opening XLF files, I get a server busy popup and have to switch to excel before my worksheet will load, but once I do that it seems to work fine.
tendernips (BOB member since 2017-07-27)
