Webi Document
Could you please provide me a sample code to extract following information for XI R2 WEBI document
  1. Data Provider SQL
  2. Objects Used in the Report
Kind Regards.
godgift :india: (BOB member since 2004-07-09)
  1. You can use DataProviderSQL() function at the report level to capture the SQL.
2.WID Scanner from BOB downloads can help you out.
Many thanks for replying. Can DataProviderSQL() be used in VBA.
Kind Regards,
Yeheya
