Hi All
I have arequirement where I should provide the option for user to enter ID and once he enters the ID the report should fetch the other values based on ID.
I have done this using promt. Now One more criteria they were asking for is
There should be a prompt on Name and if user enters either of them (ID , Name), based on that the report shd fetch values but not on both.
For ex: if he enters ID as 10 then it should not ask for entering Name, and the report shd fetch values for ID. If he dont know the ID , then user shd enter Name, so that based on name, the report shd run. but in any case it shd not ask user to enter both values.
Any Luck?
Thanks in Advance
Anu
Asmitha
(BOB member since 2008-06-06)
(BOB member since 2005-07-18)
(BOB member since 2007-05-21)
