I need to code some automation for universe maintenance ( add/modify class objects) and as per my understanding this can be done only using the Universe COM SDK.
I have checked the API guide…however i am hoping to find some sample code that can help me get started. Can you kindly suggest some pointers?
My enterprise installation is with Tomcat/Java BOXI 3.1. To be able to run my COM SDK code against this Enterprise, what additional steps would be required.
