Of course, IDT and UDT tools work well ! Do you have an idea ?
Hello experts,
About the SAP BI Repository Documentor, I am receiving an error when trying to extract the data with this tool.
It says “Failure in btnExtData_Click() : CrystalEnterprise14.FW_InfoObject.1 - -2147210694: 1000440”.
I guess that there is a problem with a corrupted object in the repository ? What do you think about it ?
Thank you for your help
Can this tool be updated to work with SAP Business Objects 4.3?
Can you please share the working copy of the excel macro after changes you made
I have a problem with this tool:
My environment:
- SAP BO 4.1.3 Patch 1
- 5 server in cluster.
Please help.
Hello,
you should change the line as follows:
Dim xml_doc As New DOMDocument60
Hi Surika,
Did it work for you?
How do we edit excel macros? do we need visual basic editor.?
yes, it works fine.
To start the VBA editor press Alt+F11.
Any tips on running this on a 64 bit box? Or not possible?
x64 SAP BI Repository Documentor_beta1.zip (2.4 MB)
Not sure if anyone still cares about this Documentor. But I managed to get it working with Office 365 x64 (ChatGPT did most of the work). I just completed a documenting of 77,000 reports and 180 universes. There was one error towards the end (CrystalEnterprise14.FW_Properties.1 - -2147210697: Item 2 was not found in the collection 1000440), but I clicked ok and the data collection finished.
I don’t know if there is any other tool out there that performs the function of this spreadsheet. Hopefully somebody can update this to include modern objects like Lumira dashboards, etc.
(Server: BOBJ 4.2.8.3, HANA CMS)
(Client: Windows 10, Office 365 x64, BOBJ Client Tools)
-Mike
