SAP BI Repository Documentor - SAP BI BusObj 4
Very good repository documenter. Thanks for help.
This utility does not capture any BICS connections, I am wondering if you can please add something for BICS connections.
AHK (BOB member since 2014-05-27)
Is it possible to use the repository documentor with BO 4.1SP2 and Office 2013? I get the following error:
Failure in get Categories()
CrystalEnterprise12.SessionMgr.1 - -2147210751: The secEnterprise DLL could not be found or does not exist 1000440
Holger81 (BOB member since 2014-02-05)
this tool is very handy. But i can not use it with SAP logon. Or is there another file? i only see enterprise, windows AD, LDAP, not SAP
Swimmer :netherlands: (BOB member since 2006-08-23)
The information on Disabled is inaccurate. I need to know the status (enabled, disabled) of the enterprise and Win AD user. How do I accomplish that? I would need the values of BOTH. The values in the first or second changes between enterprise and AD.
Lbruegging (BOB member since 2012-02-15)
Just wondering if anybody has updated the script for BW BICS connections.
gina :ireland: (BOB member since 2004-06-29)
while trying to run,I am getting below error though I have excel 2010 in my desktop…
Run-time error ‘-2147417848 (80010108)’:
Automation error
The object invoked has disconnected from its clients.
Bidya
swaib1 (BOB member since 2008-07-03)
I am also getting same error as Bidya. I am using Excel 2010 to extract from BO 4.1. I have client tools installed and checked all the 14.0 libraries. Please suggest any solutions.
Automation error
A_bouser (BOB member since 2004-10-05)
I have the same issue , i want to log in with sap authentications.
were you able to find some solution for that
BITech guy (BOB member since 2015-02-25)
Hi Sushir,
First Thank you for the providing the Macro script which fetches all BO repo Information.
However, in BI 4.1 we have additional client tools like Design Studio and Explorer and we need documents of those explorer(Information Space and Eviews) and design studio( AAO) types.
i am trying to edit the script by adding these additional tools/types into the script but i am not able to fetch the data for information space , eview and design studio in the document tab/sheet.
could you please help us on this requirement.
Nagaveni
Nagaveni (BOB member since 2012-08-23)
First of all, many many thanks for sharing the utility, you have always provided great utilities to BO community… Hats off… :+1:
Second, I tried running this on our system and we have Windows AD authentication but getting the same error as Bidya and A_BOUSER.
Could someone please guide me how this can be corrected? As it seems the same issue is faced by many users here…
This was working fine for me a couple of months ago and now it gives the same error. What is causing this?
fknaut :us: (BOB member since 2005-08-04)
The error I get is -
CrystalEnterprise12.SessionMgr1. - -214721105: Enterprise authentication could not log you on. Please make sure your login information is correct.
We are using Windows AD authentication.
Hi, I am not able to make this run … :hb: :hb:
And today, getting different error … :frowning: :frowning:
Automation error
Can someone please guide me how can this be resolved?
I am getting an error and compilation Error, Please help how to avoid this error.
Dim SessionManager, Sess As SessionMgr
gmoorthyp (BOB member since 2005-08-29)
Searched a lot to find some solution , but no Use… :hb: :hb:
Hi There, I did edit the macro and intent 6 esession.Logoff as 'esession.Logoff and I had to remove excel from Output Document Types: and it works like Charm in BI 4.1 SP4
Thank you,
K. Narkunan
narkunan (BOB member since 2015-05-02)
In SAP 4.1 SP5 I tried to use it but i get an compile error. (Can’t find project or library)
I used version 9 of this excel tool.
TurningPointHolland :netherlands: (BOB member since 2006-09-06)
Not listing dashboard reports with BO4.0 SP9
godric7gt (BOB member since 2012-04-23)
Hi narukunan
I am trying to run the version 9 Macro on Windows 7 Machine with Microsoft Office standard 2010 version, BI4.1 SP5 Patch4 or BI4.1SP2 Patch4.
When i click ‘Extract Data’ button, the Excel application freezes and say’s not responding. Do you have any idea how to get this fixed.
Arun
passport (BOB member since 2010-05-07)
Hi Sushir!
First of all thank you for this great tool.
Unfortunately I get this error… What has to be changed in the code?
Using winAD as authentification method
CrystalEnterprise14. FW_InfoObject.1 - 2147210694: 1000440
Thanks for your hints!
bobnoob (BOB member since 2010-09-16)
