Can we retrieve all table names used within derived table’s SQL (or in general any SQL - ANSI or other)?
Appreciate your help.
Thank you,
Gaurav
gauravsays
(BOB member since 2009-12-01)
Thank you,
Gaurav
gauravsays
If its DeskI report then check the List objects in a report utility from BOB downloads or WID scanner for webI reports
You can as well check the DataproviderSQL function in DeskI
haider
(BOB member since 2005-07-18)
Hello,
I should have been little clear
for e.g. if there is a derived table “User activity” in universe “SLT.unv” that has SQL like “slect * from emp LEFT OUTER JOIN dept ON edeptno = ddeptno”
than the macro should list two tables emp, dept as output.
the macro repeats for all derived tables in the universe.
Hope this makes my query clear
Best regards/Gaurav
gauravsays
You may have to improvise on the VBA code(can be found in SDK section or the list objects utility) to read the derived table code in the generated SQL
haider
