BusinessObjects Board
Properties not showing up
When I double click or Right click and select the Properties, the Properties window is not showing up. This is for all components and in all Xcelsius reports. I am using Xcelsius 2008. Under View–> Properties is Selected(Checked).
This was all working till few hours back. Properties have disappeared all of the sudden. I have even restarted the machine. Any Ideas to bring back the properties?
Diana_baker (BOB member since 2005-03-18)
I am seeing the same behaviour, I can only modify the properties on the canvas.
As I type this I have found a solution.
Open the object browser, right click on the object and select properties.
This then “resets” it to the default behaviour !
:smiley:
Ross
:hb:
Let me retract that statement, it worked once for one component.
I’m off to get my most recent backup (this morning, I know !!!)
Ross
RossGoodman :uk: (BOB member since 2004-03-23)
probably the window is visible, but has wrong coordinates so you don’t see it.
You can reset Xcelsius windows to their default positions this way:
close all instances of Xcelsius
“Start” button ->Run…
In the dialog type regedit
In the registry editor, find the key HKEY_CURRENT_USER\Software\Business Objects\Xcelsius\Settings
and delete it
Close the registry editor
Now start Xcelsius, and you should be able to see and use the properties window
Margaret
MargaretG (BOB member since 2008-06-03)
Thanks, thats a handy “hack” to know, just in case.
Unfortunately that is not what is happening in this case.
The properties window is visible, it just does not show me the properties of the component that I have selected, it is “stuck” showing the properties of the canvas.
Ross
I believe that it indicates some error in the model. If you save the file, restart the application, and reopen the file, does it fix the problem?
Sorry for the late reply. In my case the properties was not showing up until I move the Mouse/cursor to Right scrollbar on the window. It is kind of weird though that the properties are always hiding until I move the cursor there.
I just figured out…it is because the properties window is in ‘Auto hide’ Once I expanded it, I clicked on the ‘Auto hide’ icon(looks like ‘small bell’ on top of properties window), the properties window stays on.
I just encountered a similar situation where I could not find my properties window. The problem was created by me when I made the following combination of changes: First, I changed the properties window to “float” instead of being embedded in the Xcelsius desktop window. Second, due to an unrelated issue, I had switched my monitors’ position in the Windows XP “Display Properties: Settings” dialog box. I work with two monitors and changing monitor positions caused my properties window to float out of view.
Deleting the Settings folder under Regedit, Applications… as suggested did not help. Restarting the computer did not help. Reinstalling Xcelsius 2008 did not help. Finally I went back to my Windows XP “Display Properties: Settings” dialog box, switched the monitor positions, and viola, there was my floating properties window. I dragged it back into the Xcelsius desktop window, switched my monitors back, and now I’m good to go.
Just fyi.
Gary.A :us: (BOB member since 2008-10-03)
Hi Gary,
deleting the key
in the registry should always reset windows to default position. You just need to make sure that all Xcelsius instances are closed before you delete the regedit key - otherwise it does not work.
Margaret
Thank you, Margaret on the regedit solution
Thanks Margaret…Your fix helped me…
meenaj (BOB member since 2005-01-12)
I had this problem with SAP Dashboard designer as well
Just delete
HKEY_CURRENT_USER\Software\SAP BusinessObjects\Dashboards\Settings
Thank you Margret for finding this!
jamiethedba (BOB member since 2008-02-20)
