Prompt Already Exists
Any ideas on this one?
Version 6.1b (also occurs in other V6 releases)
If i edit a query and add a new prompt I receive the error
“Prompt already exists”
A prompt with the same name did exist at one point in the report, but has long since been deleted.
This occurs for a number of reports with various prompts.
I built a new test repository with a dummy connection etc and dumped the unv and report into it,
Simply to see if the error occurred when accessing the query panel and adding a new prompt.
So it’s not repository related…
Any ideas?
Reporter Bloke :uk: (BOB member since 2004-05-20)
I had a similar problem once but, when I removed all the conditions from the panel and re-entered them it worked for me. Sometimes its funky to make things work in Buinsess Objects…
Bharat :india: (BOB member since 2004-05-03)
Let me guess. The query wasn’t purged before it was deleted? Have you ever heard of phantom queries? I bet it’s still “there”…
Goto Data manager, click on each of your queries and click the “purge” button on the right panel.
PBS_rocks (BOB member since 2004-03-17)
I’ll give it a go -
although unfortunately will have to do this for 100+ reports with
multiple queries in each report :frowning:
