we have requirement where from a webi report…we need to pass
parameters to a xcelius dashboard.
we know that we can open a dashboard from a webi report by putting a cell as html link.
but here we need to pass a parameter on to the dashboard.
Please let us know how to do about this.
thanks
krishna
I have so much going around me and doesn’t have a chance to reply. I successfully tested the functionality for passing values from web I to dashboards.
I tested to pass couple of values,
For web Hyperlink: Servername:portnumber/OpenDocument/opendoc/openDocument.jsp?sKind=Flash&iDocID=157457&lsSvar=([Object 1 value])&lsSvar1=([Object2 value])
Svar and Svar1 are two flash variable to pass into dashboard
In the xcelsius select a data provider for flash variable and name it as var for instance
In the definition of flash variable, variable data ranges add two ranges one with var and other with var1(name should be same as syntax) and bond them with two cells in excel respectively.
And when your are binding the prompt cells for QAaws, bind them with above mentioned cells.
I am attaching the dashboard, I cannot send you the web I report.
Let me know if you have any questions
thanks,
Sunil test2.zip (5.0 KB)
I tried your suggestion and it worked but not 100% because everytime I save the hyperlink as you specified this one gets cut. I mean this, this is the link I configured in the webi report:
