Hi all,
In my user oracle db all columns have comments. Did you know can I simply copy all the comments directly in object description in the repo ?
I want to update the field UNV_OBJECT_DATA.OBJ_DATAVALUE with oracle comments.
regards
Hi all,
regards
May be this topic would help you…
cpmohanraj
(BOB member since 2002-09-23)
Ok thanks I’ll try
regards
