Object Description Automation
I need to give description for all the objects in the Universe. I already have the description of all the classes and objects in an excel sheet with me. Is there a way to upload the description directly into Designer ? Or do i need to write the description of each object manually?
Please help
Ishu
ishu1404 (BOB member since 2010-02-03)
Give this utility a try:
Hi Marek,
Thank you very much for sharing the Utility. It works fine for me and has saved huge amount of time :slight_smile: :slight_smile:
Thanks once again
Ishu
