Monitoring Scheduler
How do you monitor all the publications in XI
di652 (BOB member since 2005-02-24)
Can you be a little more specific (i.e. what is it you want to monitor)?
jwaterbury :us: (BOB member since 2007-09-21)
If you are looking at monitoring the status of rthe schedule,
You can check that in the instance manager in CMC.
-Aruna
arunmozhi :india: (BOB member since 2007-12-26)
Some useful posts on monitering, here:-
http://help.sap.com/businessobject/product_guides/boexir3/en/xi3_monitoring_guide_en.pdf
https://bobj-board.org/t/108409/9
http://www.sdn.sap.com/irj/boc/innovation-center?rid=/webcontent/uuid/b08e88db-7a98-2b10-8bbd-a699b7bd0290
Here’s a link another tool I use daily
https://bobj-board.org/t/80856
Yep, and a very good one that is too… :slight_smile: . I have used this on a number of projects.
Thanks so much
