Is there a macrocode using which the format for object mentioned in excel would be automatically applied to the objects in the universe.
Could any one please help me with this
regards,
Anoop
anoopwins (BOB member since 2009-03-18)
regards,
Anoop
What is available is this:
You may find it useful.
Marek Chladny
(BOB member since 2003-11-27)
I have used Dwayne’s Code and modified a little to update the object formats. I have used it for Numeric, Character and Date Objects.
Copy and Paste the following code in an Excel VB Editor and run the macro from it. Make sure that you are referencing the Business Objects 11 Library.
a) Open the Excel.
b) Click Alt + F11
c) Copy and Paste the below Code… (make changes as per your needs)
d) Press Alt+F8 to run the macro.
Used : EXCEL 2003, DESIGNER XIR2
Note : This code directly updates the Universe. First test it on a sample universe, next go for the original one.
Option Explicit 'require variables to be declared before being used
Dim DesignerApp As Designer.Application
Dim Univ As Designer.Universe
Dim Wksht As Excel.Worksheet
Sub UpdateObjectFormats()
Set DesignerApp = New Designer.Application
DesignerApp.Visible = True
Call DesignerApp.LogonDialog
Set Univ = DesignerApp.Universes.Open
DesignerApp.Visible = False
On Error GoTo ErrorHandler:
Set Wksht = ThisWorkbook.Worksheets("Objects")
Wksht.Unprotect
Wksht.Cells.ClearContents
Call MakeChanges(Univ.Classes)
MsgBox ("Changes Updated")
Univ.Save
DesignerApp.Quit
Set DesignerApp = Nothing
Exit Sub
ErrorHandler:
Univ.Save
DesignerApp.Quit
End Sub
Sub MakeChanges(Clss)
Dim RowNum As Long
Dim Cls As Designer.Class
Dim Obj As Designer.Object
Dim Rng As Excel.Range
For Each Cls In Clss
For Each Obj In Cls.Objects
If Obj.Type = dsNumericObject Then
Obj.Format = "0;-0;0;0"
Obj.Format.Alignment.Horizontal = dsHorizontalCenter
Obj.Format.Alignment.Vertical = dsVerticalCenter
Obj.Format.Alignment.RowbyRowAutoFit = True
Obj.Format.Alignment.TextWrap = True
Obj.Format.Font.Name = "Arial"
Obj.Format.Font.Size = "9"
Obj.Format.NumberFormat = "0;-0;0;0"
End If
If Obj.Type = dsCharacterObject Then
' Obj.Format = ""
Obj.Format.Alignment.Horizontal = dsHorizontalLeft
'Obj.Format.NumberFormat = "0;-0;0;0"
End If
If Obj.Type = dsDateObject Then
Obj.Format = "mm/dd/yyyy"
Obj.Format.NumberFormat = "mm/dd/yyyy"
End If
Next Obj
If Cls.Classes.Count > 0 Then
Call MakeChanges(Cls.Classes)
End If
Next Cls
End Sub
BO_Chief
(BOB member since 2004-06-06)
Thanks for the macro code.
But when i run the macro i am getting the following error
Run time error-430 : class doesnot support automation or does not suppor expected interface.
Is there any ways to resolve this issue?
Expecting everyones help on this.
regards,
Anoop
@Anoop:
Are you referencing the correct library of Business Objects Designer …?
BO_Chief
