I need some help designing better (like Cascading) Drill filters.
I have a situation, where i need to pull Dimensions like State Code, Division and District onto Drill filters area in the drill mode.
What i want is, when i select particular State like CA in the State filter then Division should list only corresponding to CA, non other. So the District. I need Division should filter on State and District should filter on Division and so on.
But i am not looking for Cascading Prompts. What i am referring here, in the Edit report report mode, we can drag objects as Drillable Objects onto Drill filter pane(Enable Drill Mode). There we have LOVs as drop downs, if we select the value in the drop down correspondingly report will change.
There we can add objects as Hierarchical wise, so i need 2nd level object should display only corresponding to 1st level object.
Suppose we have: State …Division
If i select CA as state, my drop down list in Division should display only CA divisions.
That’s how it works already. If it’s not working that way, then you probably don’t have proper data. Here’s a screen shot showing same from Island Resorts. I have selected the “West” Region, and note that the pull-down for City only shows appropriate cities. I did not have to do anything special to make this work, it’s the natural behavior.
In Island Resorts region is already from a different table than state, which is the example I mentioned above. It works fine.
It doesn’t work going ‘up’ because there might be more than one city with the same name. Suppose I selected Portland. Do I mean Portland Maine? Oregon? Texas?
Rumor has it that the reason the TV show “The Simpsons” takes place in Springfield is because every state has a city named Springfield.
In any case, when you select only from the lower level then “all” values from the upper level are displayed because it doesn’t know which might be appropriate.
