system
August 7, 2009, 2:19pm
1
i’ve several universe point the same database.
i need to know in which universe a certain table/field is used.
is there a way to do it automaticly?
something like export object definitions from universe to excel, flat file …
or a search over all the universe on my server?
thanks in advance,
Maurizio
mdepaolis (BOB member since 2009-07-06)
system
August 7, 2009, 2:26pm
2
Welcome to B:bob:B !
Use this utility to document your universe:
Author: Dwayne Hoffpauir, EDS Corporation
Notes: The attached utility uses Excel and the Designer SDK to document a universe. Usage is rather straightforward. Click the “Document a Universe” button on the Control Sheet, log in, and select the specific universe. Information will be recorded on separate worksheets for:[list]Database tables
Database columns
Joins
Contexts
Classes
Objects
Conditions[/list]
[Moderator Edit: Added BI4 Download Link in this post - Dave Rathbun]
Document a…
Use it more times because it can document only one universe at a time.
Then search for an object in the results.
system
August 7, 2009, 2:52pm
3
thank you very much,
your help solve my problem
