how to create Current date or sysdate objects in designer
Hi ,
i want to create current date object.that object have CURRENT_DATE or SYSDATE(i am using SQL Server DB ) .i am trying to create that object but its giving errror. this object, i have to use in the report level.
means clients will drage that object and use this filter , its will run the report using today date.(in report i want to see today date information only).
any one can u please how to create an object using current_date or sysdate in desingnet
ramireddy.g (BOB member since 2005-03-24)
In SQL Server it’s getdate().
Edit: When parsing objects that do not reference a table Universe Designer will always throw an error message at you. You should verify object by dragging it into a report (together with an object that does reference a table).
wahey :netherlands: (BOB member since 2007-05-31)
What you can do though to not get the parsing warning message is to fool designer…
case when 1=1 then getdate() else dbo.ANYTABLENAME.ANYCOLUMNNAME end
Darth Services :uk: (BOB member since 2007-11-20)
Hello, sorry I have a problem me to on current date.
In my designer i want to make an object who receives just the current date. I tried with curdate and current_date() or with getdate() but it’s the same mistake: check the manual for the right syntax to use.
Could you help me?
thanks
ssg9377 (BOB member since 2009-05-04)
First: what database are you using.
Second: see this FAQ entry.
