Hey,
is it possible to schedule a deski document and execute the macro in this document?
How do I execute a (vb)macro on the XIR2 server???
Thanks for your help!!!
Joachim
Joachim74 (BOB member since 2005-09-22)
Hey,
Joachim
Put the code in the Document_AfterRefresh event, and as long as you are running on a Windows server, it will execute when a scheduled refresh occurs. There is no longer an option to trigger a VBA procedure as a separate action (like in BCA).
Dwayne Hoffpauir (BOB member since 2002-09-19)
From BO I got the message, that VBA macros are no longer supported on schedules!!
Now I try to find a simple way to do the same with vbscript, but everything failes âŠ
This is incorrect information.
Ensure that VBA is installed on the server. In my case the first installation did not install (I do not know why as i do have the logs of previous install to investigate further). I did a reinstall and VBA was installed this time and i am able to schedule a deski report with a macro.
Thanks, Mani
-----[/code]
nnemani (BOB member since 2004-09-28)
I know that some functions still work,
but Business Objects does no longer support executing VBA on the server (scheduling): xir2_mig_devsuite_en.pdf (page 28 )
Changes to server side execution
In BusinessObjects Enterprise XI R2, the Desktop Intelligence report engine
and job server have changed. As a result, there are some constraints:
 The new platform scheduler does not support custom VBA macros.
 VBA add-ins cannot be executed on the server. The new report engine
does not support opening multiple documents at the same time. For
example, a document that includes a Web Connect data provider will fail
to refresh (DPVBAInterface code would need to be in the document itself
to be executed).
 CreateObject(âBusinessObjects.Applicationâ) will fail. The new report
engine is not a COM automation server.
 Documents.Open or Documents.OpenFromEnterprise will fail. The new
report engine does not support opening multiple documents at the same
time.
Yes, I am aware of a limited support for VBA in XIR2.
That is simply not true. Please see my earlier post for a clarification.
One other limitation is anything that is interactive will not work. Things like custom menus / toolbars, VBA userforms, MsgBox will only work using the client installation of Desktop Intelligence. Executing the report on the server (interactive or scheduled) appears to simply âlock upâ waiting for response to anything interactive.
Where and how could i do that. Could someone provide me more explanation about how to execute an embed VBA macro when a report is schedule, or which doc contains this information, canât find anything in admin guide.
jerryf (BOB member since 2006-02-13)
The technique is not really specific to scheduling. It is related to the SDK, and youâll find the documentation in the Developer / SDK areas. Briefly, the steps are as follows:[list]- From Desktop Intelligence, press Alt-F11 to start the VB Editor
Private Sub Document_AfterRefresh()
'put your code here
End Sub
[/list]Whenever the document is refreshed (manually, or when scheduled), the code will run.
I have followed your directions and the macro works great on the client side but I can not get the macro to run on the server.
I have manually refreshed the doc on the server and I have also scheduled the dcsument and the effect is no macro execution.
here is my macro.
Private Sub Document_Afterrefresh()
Dim returnValue As String
returnValue = SaveAsHTML()
End Sub
Private Sub document_open()
ThisDocument.Refresh
End Sub
Function SaveAsHTML() As Boolean
Dim ThisDoc As Document
Dim ThisReport As Report
On Error Resume Next '* Refresh the current report
Set ThisDoc = ActiveDocument
Set ThisReport = ThisDoc.ActiveReport 'active report
Dim HTMLName As String
HTMLName = "C:\Temp\" & ThisReport.Name
Kill (HTMLName) 'Delete existing file
SaveAsHTML = ThisReport.ExportAsHtml(HTMLName)
End Function
Moderator Edit: Added BBCode to distinguish VBA Code. - Michael
mcornel (BOB member since 2004-05-11)
with the removal of the ability to run VBA externally to the reports, how does one now go about breaking up an instance of desktop intelligence report into multiple files (eg PDF) based on something other than users and profiles?
any ideas?
thanks
icytrue (BOB member since 2006-04-10)
Did anyone make this to work? I am able to execute macro on client in after_refresh event but scheduler(server) it is not executing?? Do we have any setting on server ???
dcdas (BOB member since 2002-06-17)
If breaking a report into muliple instances is the core issue, then this can be accomplished by using the âpublicationâ feature of XI r2. The publisher is 6.5 is part of XIR2 and this should take care of bursting the reports to multiple groups.
NBG (BOB member since 2005-07-18)
I think the âpublisherâ part is available only if you have a âpremiumâ license which is an upgrade of the âprofessionalâ license.
You need premium to do multi-pass bursting and make use of publication profiles.
Irwin Miller (BOB member since 2002-08-16)
This doesnât surprise me, as Publisher was an expensive upgrade in v2.7.x and v6.x!
DJ
DJ06482 (BOB member since 2002-11-22)
I have a macro that sets default values for a date prompt and then creates PDF files using the ExportPDF function. I also write to a log file to trace what is happening.
When I run this DeskI report from my workstation and set Application.Interactive true everything works fine.
But then I export to CMC and schedule it to run. The instance created has the correct date periods and the report is correct. But no PDF files are created and the log file reflects this. In the logfile, there is an indication of an ERROR 100 - No current report plus gibberish for the report name.
Anyone have any ideas or had similar experience?
Sorry I meant Application.Interactive = False
Could you post your code??
This is the logfile output:
ERROR: 100 - No current report
Start of macro for: ~fc_16b84454c824461
Start of refresh of: ~fc_16b84454c824461
Start of Filer and Export
It appears as if it does not recognize the variable âThisDocumentâ.
In an earlier release (5.x) I had to use
Dim boDoc As busobj.Document
' In ThisDocument
Private Sub Document_BeforeRefresh(Cancel As Boolean)
' FOR TESTING, uncomment this next line... It suppresses any prompts
' If refreshed from batch (BCA) then set default prompt values
If Application.Interactive = False Then
Call InitSetup ' set up path and file names
Call SetReportParams
End If
End Sub
' If refreshed from batch (BCA) then IN THE FUTURE create PDF files
Call FilterandExport
End If
' FOR TESTING, uncomment out this next line... It enables any prompts
Application.Interactive = True
End Sub
' In Modules
Option Explicit
Dim sPathName, sLogFile, sLogMsg As String
Dim sDocName, sExportPath, sExportFile As String
Dim sVariableName, sFilterCond, sDateStr, sNextValue As String
Dim boDoc As Document ' busobj.Document
Dim borpt As Report ' busobj.Report
Dim boFilterVar As DocumentVariable
Dim i, nNumChoices As Integer
Dim myFilterChoices As Variant
Sub InitSetup()
On Error GoTo ErrorHandler
' Default pathname, filename for PDF files
' For TESTING - write to local drive
sPathName = "c:\temp\"
sExportPath = sPathName & "BO Reports\"
sLogFile = sPathName & "logfile.txt"
' This document is the active (Open) document
Set boDoc = ThisDocument
' sDocName = bodoc.FullName contains the path and .rep
sDocName = boDoc.Name
' This report is the active (with focus) Report
Set borpt = ActiveReport
Call LogMessage("************************************")
Call LogMessage("Start of macro for: " & sDocName)
Exit Sub
ErrorHandler:
sLogMsg = "ERROR: " & Err.Number & " - " & Err.Description
Call LogMessage(sLogMsg)
Resume Next
End Sub
Sub SetReportParams()
' This procedure is called just before the document is refreshed
' It is only called in non-interactive mode (Application.Interactive is False)
' where prompts are not displayed
Dim nMonth, nYear As Integer
Dim dStart, dEnd As Date
dEnd = Date - 1 ' Ending date is yesterday
dStart = DateAdd("d", -24, dEnd) ' Starting date is 24 days before
boDoc.Variables.Item("1. Enter Starting Date").Value = dStart
boDoc.Variables.Item("2. Enter Ending Date").Value = dEnd
Call LogMessage("Start of refresh of " & sDocName)
Call LogMessage("Between " & Format(dStart, "mmm d yyyy") & " and " & Format(dEnd, "mmm d yyyy"))
End Sub
Sub FilterandExport()
' This procedure is called immediately after the document is refreshed:
' For a given report variable (such as Engine Family)
' filter the report for each value of the variable
' Save (export) each filtered report as a PDF file
' For debugging, this shows the actual variables in the document
' nNumChoices = bodoc.DocumentVariables.Count
' For i = 1 To nNumChoices
' myFilterChoices = bodoc.DocumentVariables.Item(i).Name
' Next i
Call LogMessage("Start of Filter and Export")
' Date will become part of filename
sDateStr = Format(Date, "yyyy-mm-dd")
' First export by each Engine Family using the report variable
sVariableName = "Engine Family(Start in Period)"
Call ExportByFilter("EF", sVariableName)
' sExportFile = sExportPath & sDocName & " " & sDatestr & ".PDF"
' Call LogMessage("Saving as " & sExportFile)
' boDoc.ExportAsPDF (sExportFile)
Call LogMessage("End of macro for: " & sDocName)
End Sub
Sub ExportByFilter(sLevel, sVariableName)
Dim sFile As String
Dim botab As Report
Dim nNextValue As Integer
' This procedure examines sVariableName and determines the
' distinct values in the doc. For each value, a filter is applied
' to show only that value. The filter is applied which produces
' a new view of the data. That view is then saved as a PDF file.
' sLevel is a literal that becomes part of the PDF file name.
Set boFilterVar = boDoc.DocumentVariables(sVariableName)
' find out how many values there are for this variable
nNumChoices = UBound(boFilterVar.Values(boUniqueValues))
' collect the number of choices in a variant variable
myFilterChoices = boFilterVar.Values(boUniqueValues)
' Get the variable value
sNextValue = myFilterChoices(i)
' build filter
sFilterCond = "=<" & sVariableName & "> = " & sNextValue
' Refresh each report tab
For Each botab In boDoc.Reports
botab.AddComplexFilter boFilterVar, sFilterCond
' Set the report title to include the filter value
boDoc.DocumentVariables.Item("Report Title").Formula = "Engine Family: " & sNextValue
' Recompute the report (which applies the filter)
botab.ForceCompute
Next botab
' now export to desired format, using the
' literal sLevel and the filter value as part of the name
' use boDoc object with ExportAsPDF method to save all report tabs
sExportFile = sExportPath & sDocName & " " & sDateStr & " (" & sLevel & "-" & sNextValue & ")" & ".PDF"
Next i
' invoke a filter that is always true to undo the filter
' botab.AddComplexFilter boFilterVar, "=(1=1)"
' botab.AddComplexFilter boFilterVar, "=<Engine Family(Start in Period)> <> " & Chr(34) & "N/A" & Chr(34)
botab.AddComplexFilter boFilterVar, "=<Engine Family(Start in Period)> <> 0"
boDoc.DocumentVariables.Item("Report Title").Formula = "ALL ENGINES"
botab.ForceCompute
Next botab
End Sub
Sub LogMessage(sLogMsg)
Dim msgText As String
Dim nFile As Integer
nFile = FreeFile ' get the next free file handle
Open sLogFile For Append As #nFile
msgText = Format(Now, "mm/dd/yy hh:mm:ss") & " - " & sLogMsg
Print #nFile, msgText ' using Write instead of Print added quotes to the string
Close #nFile
End Sub
