Document a universe using Excel and the Designer SDK
Hi:
Now that is a new one. I’ve not seen that error before. I suspect something corrupt on your workstation, but there is one thing to try. Could you run the utility on a very small, simple universe, and see if it generates the same error?
I tried small to medium size universes, got same error message every time.
In fact, I downloaded other utilities like WD Scanner, got the same error message once it completes the execution.
The utility is recursive (calls itself as it moves down the folder tree), but if the error persists on a small universe, it eliminates the possibility that you’ve run out of memory.
I have 4 GB of memory on my box. I will try investigate further again.
Ramesh Vasudevan
rameshbalajiv (BOB member since 2008-03-25)
… and the WID scanner doesn’t even use Designer (I don’t think). Sounds more and more like a local workstation issue, I’m afraid.
when i am working with to dowload a universe as excel document of XIR2 universe the following error was coming. please can u give me a solution to resolve this problem.
( VBAProject - 430 : class does not support automation or does not support expected interface )
regards
sekhar
[/u]
bsekhar1980 (BOB member since 2009-01-16)
Hi Dwayne
I get the same error as well
Using Excel -2007 and on another PC Excel 2003. Get the same error both ways.
The library is fine, it does use The BOXI one. The compiler highlights the first line of code
Sub DocumentUniverse()
How do I fix this?
meenal (BOB member since 2006-03-08)
When i tried to Document a universe.
i am getting the following error
VBAProject -430 : Class does not support Automation or does not support expected interface.
universe version : XIR2
Please help me on this…
vickys (BOB member since 2007-11-08)
Questions for bsekhar1980, meenal, vickys. What version of Excel? I know meenal said both Excel 2003 and Excel 2007 give the error, but I have my doubts about Excel 2003 giving that error.
I get the error universally (pun intended) with Excel 2007. Honestly, haven’t had the time to see if BusObj is aware of the issue.
Hi Dwayne,
I am using MS office Excel 2003 SP2.
Any suggestion for resolving this problem is appreciated…
Compiler highlight below line :
Set DesignerApp = New Designer.Application
I’m at a loss, since I use that version of Excel myself, and I’m guessing the majority of the thousands of downloads do as well.
I can only suggest typical debugging at this point, like trying on a co-worker’s machine, download a clean copy, etc.
Thanks,BUT,I did not get the information of Derived Tables in that,just the tables,columns from pointing do Database,Please can you tell me how to find the Derived Tables?
Naveen Vanaparthi (BOB member since 2008-07-02)
Thanks,thats a good tool,BUT How to get information of DERIVED TABLES?
Hi, posting your question twice isn’t really going to help get it answered any quicker … and especially not when the answer to your question lies within the very same thread you asked the question in :roll_eyes:
HINT: Try page 5 and see if that helps :wink:
Peter Hughes :uk: (BOB member since 2005-11-21)
sandeepk66, please do not bump your post until at least one business day has passed.
I am trying to document a XI 3.1 universe, but I am getting an out of memory error. It is in the LictConditions() section.
Franko418 (BOB member since 2004-07-07)
I was wondering if there is any tool that can document by report name, the corresponding classes/objects & the table/column name. i.e. Excel with report → class/ objects used → Table.column name? The reason for this is I am looking at 250 odd XIR2 reports that needs documenting.
pravin_kadambi :us: (BOB member since 2005-05-18)
Assuming you mean full client reports, look here … List objects used in a series of reports. If you mean WebI reports, there is also a WID Scanner tool here in BOB’s Downloads.
The full client utility will document the classes / objects used, but not the tables / columns directly. Remember, a single universe object could reference many tables / columns. That said, you could use the output from the full client documentation and link it (on your own) to the universe documentation, and get very close.
Thanks Dwayne. As you rightly said, I can get pretty close :slight_smile:
Anyway, two awesome contributions from you. Hats off!!! :yesnod: :yesnod:
This was great information and this macro worked wonders for me. Just wanted to say thanks
klongmire (BOB member since 2009-02-09)
while running the excel sheet for XIR2 which u posted the execution was failing at the end so can you please check and send me the correct one
it would help alot for me
Thanks & regards
krishna
09620202420
ummalety :india: (BOB member since 2009-02-19)
While I could be available to do some custom work for you, I’m fairly sure you won’t like my rates! :roll_eyes:
That said, if you could give me a few more details than “was failing at the end,” I’ll be glad to see if there is anything wrong in the utility itself. Please include what version of the utility, and what version of Designer you are using.
I’m having this same problem.
I have Business Objects Designer 12.0 Object Library.
Doesn’t appear to be any error messages (blank pane when I click Compile VBA project).
Moira
moiram (BOB member since 2009-02-20)
