First of all, Thanks a ton Marek for prompt reply and providing excellent tool.
Only one concern. I tried installing the Grep tool from sourceforge.net ( same GNU tool ) but unfortunately, when i try to run “m4.exe” file,
it gives me following error message :
" This Application has failed to start because regex2.dll was not found. Re-installing the application may fix this problem."
And I am mainly interested in retrieving all the objects. ( rite now WID Scanner works fine but does not any objects,becoz there is no GREP tool )
