system
December 21, 2007, 11:34pm
1
Author: Kalyan Tirunahari, trkalyan@gmail.com
About the Presentation:
I have documented a list of features for a BI Portal Interface
Its nice to have a BI Portal Interface with the following features rather than a Bland white screen with a Login Box.
User friendly features which make BI Portals a cool place for Users.
Features that provide a quick insight for Administrators.
Fun-Information for users.
Customized BI Interface.zip (228.0 KB)
Sheshachala5 (BOB member since 2004-01-09)
system
February 29, 2008, 10:37am
2
Nice…Do you have other scripts also for the interface after the login is done, the one where there are the folders with all tre reports. Because that creen looks quite the same as unfriendly.
Thx
cbabalac (BOB member since 2008-02-29)
system
March 13, 2008, 11:29pm
3
I guess you should have tried MyInfoview with the folders and reports to show up the way you want. Did that help?
system
August 7, 2008, 10:28am
4
Please more examples…
mr_max (BOB member since 2008-06-25)
system
August 22, 2008, 8:23am
5
Pls. provide some scripts to customize the entire environment. or Some tips for MyInfoview, which would enhance the look of the entire product.
~Harish
harish.malik (BOB member since 2008-07-14)
system
September 4, 2008, 5:44am
6
Kalyan, your other utility of customizing BI is superb.
Pls. provide some more codes and scripts to modify and enhance the look of the rest of the environment.
~Harish
system
September 5, 2008, 11:35am
7
kalyan , Thanks for giving us such a great utility. It’s wonderful.
Aniket
aniketp (BOB member since 2007-10-05)
system
September 16, 2008, 6:49am
8
Hi Kalyan,
This is a cool stuff man. Well done and Thanks for sharing.
aptsrini (BOB member since 2008-05-30)
system
September 21, 2008, 3:26pm
9
Kalyan,
Is there a similar code for ASP environment.
Please advice.
bo4u (BOB member since 2008-08-15)
system
October 21, 2008, 11:40pm
10
If you look at the code all i have done is plain HTML. I know it is a bit challenging to cherry pick that HTML out from the JSP .
But sorry, i dont have the ASP version.
system
June 25, 2009, 11:40am
11
where do i find MyInfoview? I understand its for customizing the InfoView portal?
Magnus O. (BOB member since 2009-04-20)
system
August 26, 2009, 3:17pm
12
Very Nice interface…Do you have the script for the last XIR3 plateform?
Thank you
Nicky (BOB member since 2003-02-14)
system
April 5, 2011, 10:48am
13
Thanks for sharing, that was very useful!
RGeurts (BOB member since 2006-12-29)
