Connection info + universes
Author: Joe Peters (with thanks to Dwayne)
Platform: Windows
Version: 1.0
Notes:
Joe
connections.xls (59.0 KB)
To get this to work with XI3, I had to switch not just the 3 classes you mentioned to the “12” equivalents, but also add in the BusinessObjects Designer 12 reference.
But it works great!
Thanks, dnewton. I had tested it with the 11.5 libraries connecting to XI3, which did work successfully. But I found out recently that that will cause Fail messages for Connections that were created or modified in XI3. So, although it’ll work with the XIr2 libraries, it’s better to use the XI3 libraries if you’re connecting to XI3. (yeah, I know, “duh”).
Joe
Hello
When I click on ‘Document Connection’ button in excel I get a compile error saying ‘Cant find project or library’
Do you know if the file is broken?
Namit
namitrs :us: (BOB member since 2006-11-28)
Most likely, you don’t have the XIr2 client software installed.
I could really use this download. Anyone know if there is code available for changing the Universe Password? I could use this download to verify a mass update to all my universe passwords.
efrenacevedo (BOB member since 2010-08-31)
I assume you mean Connection Password? There is a Password property of the Connection object, but I’ve never attempted to set a password with it.
Joe
Yes I meant the Connection Password? I need to change it for 50 universes and was hoping not to have to do it manually through designer…
Do you have a separate connection for each universe? If so, you should be able to use my code to iterate through the connections, then add the code to change the password. But you’ll have to test it – you might have to change it in one connection first, then get the encrypted value of “Password”, which would then be used for the remaining connections.
So I have 50 different connection names but the same username and password…
Is the password always encrypted?
I believe so. I’ve never used that property.
Isn’t the password property read-only? I may be wrong though, can’t check it now.
Hi all -
The password is writable – we have code that reads an application’s configuration file (db settings, credentials, server, etc)file and auto-deploys Universes by creating a connection, setting its parameters and finally exporting to the CMS…
Hope this helps
This is a very usefull sheet, thanks.
But when changing from one repository to an other some rows from the previous repositorie are still there.
So, before a you want to refresh this document a cleanup should be made.
hvandervegt :netherlands: (BOB member since 2003-11-17)
