system
1
Hi Guys,
I have 150 Reports. We are going to make some changes in the Universe. Now we need to compare the reports before and after the change.
Is it possible to do it using some tool without puting manual effor of comparing reports by opening them up?
Saurabh
suruworks
(BOB member since 2007-05-21)
system
2
WID scanner
haider
(BOB member since 2005-07-18)
system
3
Thanks Haider
Is it possible to get the information about the Objects used?
Like Universe and Object Parameters?
Saurabh
suruworks
system
4
That exactly what the utility says
haider
