system
December 14, 2010, 2:36am
1
Hi All
I want to calculate the difference between two times in report level.
For example:4:00 to 4:20
I need to show the difference between the two times is 20 minutes in the report.How can i achieve the same?
I tried to find in BOB forums but they used dates and calculated the difference of time in Deski.
Please help to create a variable at report level in Webi.
Thanks in advance.I appreciate your work.
passport (BOB member since 2010-05-07)
system
December 14, 2010, 6:51am
2
ToNumber( Substr( FormatDate( [Most recent timestamp] ;"HH:mm:ss" ) ; 1 ; 2 ) ) * 60 * 60 +
ToNumber( Substr( FormatDate( [Most recent timestamp] ;"HH:mm:ss" ) ; 4 ; 2 ) ) * 60 +
ToNumber( Substr( FormatDate( [Most recent timestamp] ;"HH:mm:ss" ) ; 7 ; 2 ) )
ToNumber( Substr( FormatDate( [Oldest timestamp] ; "HH:mm:ss" ) ; 1 ;2 ) ) * 60 * 60 +
ToNumber( Substr( FormatDate( [Oldest timestamp] ; "HH:mm:ss" ) ; 4 ; 2) ) * 60 +
ToNumber( Substr( FormatDate( [Oldest timestamp] ; "HH:mm:ss" ) ; 7 ; 2) )
) / 60 +
( DaysBetween( [Oldest timestamp] ; [Most recent timestamp] ) * 24 * 60 )
mikca (BOB member since 2005-12-16)
system
December 14, 2010, 4:16pm
3
Thanks a Ton…That worked…You are awesome…!!!
system
December 14, 2010, 9:39pm
4
Thanks so very much!
I had the same kinda issue,your formula worked great!
heyyin (BOB member since 2010-12-14)
system
December 14, 2010, 10:54pm
5
It is a formula that I found on BOB so gratitude to original author whose name I lost
I find it strange that BO does not have a built in TimeStamp_Diff routine
Mick
system
December 15, 2010, 8:25pm
6
Yeah Man, i am new to WEBI and i wasted some time writing something to it…
hope the next realease has it.
system
February 7, 2011, 10:25pm
7
Desperately needed this and very glad I came across this post. Thanks!
steph m (BOB member since 2008-04-11)
system
June 23, 2012, 4:59am
8
THIS May be the answer I have been looking for…or at least on the right track.
I changed the names of the fields to match my fields. [Start Time] would replace [oldest time stamp] and [End Time] would replace [Newest Time Stamp]? Right?
And if the time is labeled as a text column, how can I change it? It will not let me select any number options in the format cell menu.
I have spent hours to get a duration, and finally found this forum, so I am really hoping you can help!
THANK YOU!!!
bmorehappy (BOB member since 2012-06-23)
system
June 23, 2012, 10:52am
9
If your timestamp is already a text field then you can remove all of the FormatDate routines (which only exist to turn timestamps to strings) and use appropriate ToNumber( Substr( [Your datetime field value]; n; m) ) routines to extract the values you want.
Mick
system
January 30, 2018, 3:14pm
10
cheedalla (BOB member since 2004-04-13)
system
February 7, 2018, 11:19am
11
4.2 SP5 has new inbuilt functions for calculating time differences
jemstar (BOB member since 2006-03-30)
