please share your experience with the latest BO version 6.1b. It is out only
1 week so maybe there is already anyone that has tested this version a little.
Are there any major problems? Some bugs? Is it better than version 6.1a with hotfix 103 applied?
Well for all you flamers, I installed 61b and it has resolved the bugs we had raised - cant be more happy than that (apart from the wait). Seems to be stable, and no issues to report at thsi stage.
As written here, BOBβs search database does not contain words of 2 or fewer letters. Therefore searching for version numbers typically does not work. If you simply look through the subject lines for a page or two you will see the recent discussions, and that takes very little time.
For a work-around about searching by version see this topic.
Since Andreas has already linked to the another 6.1b topic, will lock this one. Thanks.
