is there any posibility to recover the all passwords of BO. if i forgot the all passwords including admin.
can any one tell me.
Adv Thanks
rpothineni
(BOB member since 2008-01-02)
Adv Thanks
rpothineni
You can do the Update on the Repository’s Security Domain, if you forget the password, I dont think its possible to Read the Passwords directly, since its in decrypted…
This is for the Classical Business Objects and XI have different architecture.
Update OBJ_M_ACTOR
Set M_ACTOR_C_PASSWORD = NULL
Where M_ACTOR_C_NAME = ’ ';
Siva.M
looksmee
(BOB member since 2006-02-08)
Please let us know which BO release you are using.
BR
Sebastien
Not sure if this will help, but try this post:
https://bobj-board.org/t/86032
bension (BOB member since 2005-09-01)
i am using BOXIR2 in that. In this where u can find that tables. and u can directly write the query on database itself. is it write !
Thank u
rpothineni
This query will work only with upto 6.5 version of Business Objects.
Siva.M
looksmee
please check with the table CI_systemobjects or else CI_infoobjects using query analyzer from there i think you need to update. first select and see.
Ranjan
ranjan.sahoo
(BOB member since 2007-06-11)
@rpothineni:
Please avoid Cross-posting
You have already opened multiple threads and that too using different accounts ![]()
Here
haider
(BOB member since 2005-07-18)
Plus, might I suggest that you refrain from using text-message-like words, such as u - it’s you.
wahey
(BOB member since 2007-05-31)
An Utility in BOB’s Downloads to Reset the Password in XIR2.It may help you.
Siva.M
looksmee
I forgot that password thats y i created new accout.
rpothineni
You cannot view passwords in the repository. When a user sets their password a one-way hash is created and stored in the repository, the password is then thrown away. When a user attempts to logon the password is hashed and that value is compared to the stored hash value.
jwhite9
(BOB member since 2006-07-28)
