BI Platform Security for Mere Mortals
Those that have been around this forum for a while will probably recognize the title of this message. There is a longstanding thread here. Well, I will be “reprising” the material at this years ASUG SABOC (SAP Analytics and BusinessObjects Conference), which will include a 4.1 version of the Excel-based security matrix :smiley: . I’ve posted both the tool and presentation material here, based on a Windows installation of 4.1 SP06 with the Explorer and Design Tool add-ons installed.
The matrix document basically contains two things:[list]A list of all possible rights, and where they are included in the default access levels.
A list of all of the default settings in a “clean” installation.[/list]
BI41 Security Matrix.zip (164.0 KB)
2936_BI Platform Security for Mere Mortals.pdf (1034.0 KB)
Great! I’m sure plenty of peeps will find this of great use, as before, Dwayne 8) .
This is awesome! Thanks for sharing this!!
rainmaker_ :de: (BOB member since 2010-10-28)
Presentation material added to the first post in this thread.
does this document include any script or code inside or is it only a template which you should fill manually?
i couldn’t see an macro, code etc.
thank you
bozgul (BOB member since 2006-11-06)
Just a template.
Maybe there is video of this presentation at SAP Analytics and BusinessObjects Conference?
b0user (BOB member since 2016-05-25)
thanks for this great Matrix. Do you have an Update for BI42 Sp05???
Thank you.
BO_Ela :de: (BOB member since 2018-03-23)
