I have values in a chart that are 0. I have the formatting option turned on to display 0.0% when the value is zero. It is simply not displaying on the chart. Any other value displays perfectly. Any suggestions welcome.
BIDude
(BOB member since 2009-05-14)
Charts don’t display 0s, even if you format the number that way.
You’ll need to create a variable that converts 0s into another number, such as .01, using If. Use a number that is small enough that it will still look like 0 on the chart.
MichaelWelter
(BOB member since 2002-08-08)
Does not work for percentages though the lowest i can get it to go is .1%…it will not display 0%
= If (<SLAAchieved(Sev 1 and 2 DC Resolve)>) > 0 Then (<SLAAchieved(Sev 1 and 2 DC Resolve)>/<ValidSLA(Sev 1 and 2 DC Resolve)>) Else 0.001
BIDude
Have you tried .0001? On your chart, does it look like 0?
MichaelWelter
it simply wont display anything with that vaule.
BIDude
Got it…i had to put .0004 to make it work! Thanks so much!
BIDude
