system
July 15, 2011, 12:54pm
#1
I am learning BO Admin. I created a new user ID. When I try to open Desktop Intelligence getting below error. Pls sugeest me how to get below things
Should connect to Desktop Intelligence
Should see all reports available in a Single folder with refresh option
Should not export any report in the BO Repository
I am using BO XI R3
Byomakesh (BOB member since 2009-08-01)
system
July 15, 2011, 1:24pm
#2
You need to grant the appropriate rights to your new user. The best way to do it would be to create a group and grant rights to the group.
I would also suggest you read the admin guide, it does a good job of covering security. Also have a look at this topic https://bobj-board.org/t/119849
jwhite9 (BOB member since 2006-07-28)
system
July 18, 2011, 8:14am
#3
Thank You
system
August 30, 2011, 9:53am
#4
Just go to Home->Application->Desktop Inteeligence->Rightclick->User security
Add your user group with access you want to give with below required access.
“Log on to Desktop Intelligence and view this object in the CMC” in General tab ( for successfull logon)
“Send documents to repository” in Desktop Intelligence tab (for restrciting access to repository)
Thanks & Regards
chin2G (BOB member since 2010-10-02)
