XML Problem -- Output Incomplete
I am using BODS 4.2 SP8 Patch 3.
I created an xsd, imported it and wrote a job to output an XML file for each key. I am trying to output three different value options, but the problem I am having is that only the values associated with the single value option are output to the XML file.
I have provided more detail in the attachment.
I would sure appreciate some advice for how to overcome the error.
Thank you in advance.
wynter.johnson (BOB member since 2018-10-04)
