We are trying to some data from a cloud based system. This system exposes their data using REST API. I am able to setup HttpAdapter to get data. The issue is that the reponse XML contains all the data in one XML element as a comma separated string,
When tested from SOAP UI, this string has got CR and LF but Data Services removes the CR and LF characters. Is there a config that can fix this issue? The XSD defines this element as “xs:string” which should make it accept all characters
Currently I am writing the XML response to a XML file. Is there any method to read the comma separated string (which has column headers and data rows) into a structured output?
We are on Data Services 4.2 SP2
Kind Regards
Mohan
cpmohanraj (BOB member since 2002-09-23)
