I have 7 tables through which I am trying to load xml. I am doing all the joins in a query which has xml schema. It loads 100 rows fine but when i try to load bigger set of data like 5000rows it consumes all the server ram and hangs. How to avoid this?
It would help if you provided a more detailed description of the Dataflow. A picture would help.
It might work to put a Data Transfer after the XML source so the data goes to the database. After that you can join from the table using a Query transform. That might eliminate your memory issue.
