Hi all,
I’m new to Dashboard and I have a problem with xml data connection refresh.
I created a web application that return an XML extract from my oracle db and I set the URL and I seleted application/x-www-form-urlencoder for the MIME type.
All works fine, but if I change data from my db the dashbord doesn’t refresh.
I have select all the options for the refresh as this tutorial shows http://www.youtube.com/watch?v=5lr0hWxpd4M
Second question: can I pass a parameter to my dashboard and use it as parameter of XML data connection URL?
Have you set the connection to refresh? On a trigger or time-based? Can’t view youtube here. I’m afraid…
Yes - you can pass parameters in and out of an XML connection. I do it all the time. But I just call an aspx script that runs SQL and returms XML data to my dashboard.
Sounds like a connectivity issue, then. Not something I know anything about…
Flash variables I only use to jump around dashboards and pass parameters along - eg: a user selects a location on one dashbaord then moves to another and I use a flash variable to pass this location value with a flash connection. I’ve posted how I’ve done this in some detail on this forum. But I’ve no idea how it would work in a web app - all my stuff outside of xcelsius is handled in an aspx script.
