We are processing data from XML to Oracle table (10g). One column from XML has varchar(4000) characters. When we insert this into oracle table, we get an error - error <ORA-01461: can bind a LONG value only for insert into a LONG> column.
We have tried with following datatypes for Oracle table on the varchar.
varchar2(4000 char) and nvarchar2(2000). We don’t want to insert XML varchar(4000) string to a long or clob column in Oracle. Any other suggestions would be helpful. Thanks.
Because Oracle only supports varchar2/nvarchars with up to 4000 bytes. Everything bigger is a CLOB datatype. I expect some double byte chars so at the end the XML is too large for Oracle. Is that possible?
If I have a long data type on descriptions in the Oracle table, I cannot do updates (long does not permit that) and also cannot do a distinct. XML flattening generates duplicates and I need to do a distinct operation on the result.
Adding to that I have one other update about DI handling a long column.
For a table having a column with LONG Datatype and if that is your TARGET Table and if your Dataflow is not a Push-Down SQL, then DI does a commit for Each record. I mean the Commit Size is overriden with a value of 1
I changed the target to SQL server and used nvarchar(4000) for the descriptions. I tried using bulk loads, both gave an error on space. I tried changing the recovery mode from bulk to simple to minimize logging and optimizing space. Is there any other way to turn off logging in SQL server loads with DI?
