system
February 19, 2013, 6:40am
#1
Hi all ,
I have published my dashboard on BI launchpad when i am opening it …
it is throwing an error of XLS 000003 - network connectivity to BO Server
Error - although all the connections look fine … the error message says
that some Object IDs are missing from CMS …
please, help in this regard …
meetsaiat (BOB member since 2012-05-25)
system
February 20, 2013, 10:29am
#2
hi,
please provide details of the connection used in building the dashbaord .
o/p file details, connectivity.
mohan2708 (BOB member since 2012-05-21)
system
February 27, 2013, 5:05pm
#3
Check whether Dashboard Processing server and cache server are enabled and running.
Check list for Add Query to work:
Adobe Flash installed
CMC -> Applications -> Web Service -> Access URL properly set - http://:8080/dswsbobje
CMC -> Servers -> Dashboard Design Services - both Processing server and Cache server should be enabled and running.
Luke
Rango90 (BOB member since 2012-11-13)
system
July 24, 2017, 11:51am
#4
Hi everyone. I have same problem, but dashboarsd work only with Admin rigths. I can not find where (connection, univers or other) I should add right for query dashboards. Help please.
ambaharev (BOB member since 2017-04-18)
