I was wondering if anyone else has experienced report conversion problems after upgrading to XIR3 ? …specifically regarding Merged Dimension functionality. I use a lot of variables to conditionally select what I need when multiple values exist (like qtys by year) and in new XIR3 reports I could no longer use some variables as they only gave me #multivalue result (and no, using min or max did not resolve this). I ended up having to break my single query up into separate ones to avoid the multiple values (ie: year) which in my estimate is going backwards in functionality and response time. If anyone has found a proper solution, I’d LOVE to know!
There have been other changes too now requiring use of In Section, In Report, NoFilter, etc where previously not needed
These changes were not reported as planned nor expected by us for conversion time required, so please check your reports after upgrading!
I first encountered this problem with XIR1, after which it got fixed in XIR2. to my surprise the error now occurs again in several XIR3 environments I’ve been working on !
I’m hoping to be in a position to install a hotfix soon, and curious to see if this issue was addressed … will keep you posted.
this is not an option, since the error even occurs when none of the columns contains numerical data …
take these 3 columns: , , , where the #MULTIVALUE error appears in the last column ().
now where would you use sum() …
other thread suggest the use of max() to work around this issue, but I need to display ALL product numbers for each client, not the one with max value !
I’m afraid I may have responded to the wrong thread, since the #MULTIVALUE errors I’ve been dealing with are not related to migration at all: they appear in newly created WebI reports.
