I would consider this macro to be highly specialized (not setup for Webi/Crystal), however I believe that the code has benefit as an example for you to use and adapt to meet your needs. Specifically, the examples of how to obtain the prompt info, event info and path info are useful.
Credits:
Julien Bras - I used Julien’s code from the “BOXI UserList & Group Extraction” as a base for this macro.
jrennatc from the Tek-Tips forum - I used jrennatc’s code to get the recurring instances.
Platform: Microsoft Excel 2003 / XIR2 SP4
Version: 0.2
Code:
Rather than post the code verbatim, here is an overview of the logic:
1. Connect to the CMS (Thanks Julien!)
2. First Loop - Loop through all Deski reports.
2. Second Loop - Extract the list of recurring instances.
3. Third Loop - extract info on the prompt names and values and other miscellaneous attributes.
This attached excel is working fine with BO xi r3.1 , but when I tried to get information with BO xi R2. It producing error: “Access denied, you can not use old version of CMS”
