XI4.1 Publications are not working
Until now, we were using scheduling for automating our report, by email or FTP. But now we have the need for publication with dynamic recipient, to burst reports to our FTP.
My team and I are trying to make that works since the last week, without any success. The publication always fails, even if we try a make basic one (no dynamic recipients, basic report without any prompt, just one enterprise recipient).
In the webi interface, we get the state “Failed” and the error “Internal error”.
And we get this error into the log files when the publication with dynamic recipients is triggered :
FILE_TYPE:DAAA96DE-B0FB-4c6e-AF7B-A445F5BF9BE2
ENCODING:UTF-8
RECORD_SEPARATOR:30
COLUMN_SEPARATOR:124
ESC_CHARACTER:27
COLUMNS:Location|Guid|Time|Tzone|Trace|Log|Importance|Severity|Exception|DeviceName|ProcessID|ThreadID|ThreadName|ScopeTag|MajorTick|MinorTick|MajorDepth|MinorDepth|RootName|RootID|CallerName|CallerID|CalleeName|CalleeID|ActionID|DSRRootContextID|DSRTransaction|DSRConnection|DSRCounter|User|ArchitectComponent|DeveloperComponent|Administrator|Unit|CSNComponent|Text
SEVERITY_MAP: |None| |Success|W|Warning|E|Error|A|Assertion
HEADER_END
.\DatabaseSubsystemHelper.cpp:667:-: TraceLog message 807
|7b4f58d1-095d-8584-3bf9-a304a4ce9684|2016 06 21 16:29:46:279|+0200|Error| |  |E| |cms_BOWIN1PP.CentralManagementServer| 2908|2872|| |1|0|1|0|BIPSDK.InfoStore:query|bowin1pp:7472:105.15818:1|BIPSDK.InfoStore:query|bowin1pp:7472:105.15818:1|cms_BOWIN1PP.CentralManagementServer.queryEx3|localhost:2908:2872.62820:1|CiUpvLiCWk3nlgkFI6z6NO03ced|||||||||||The value of SI_ID should be a number but instead was 4294969658
.\DatabaseSubsystemHelper.cpp:667:-: TraceLog message 808
|ea1cc5cd-de77-98d4-f96d-462fbb91d181|2016 06 21 16:30:17:498|+0200|Error| |  |E| |cms_BOWIN1PP.CentralManagementServer| 2908|2076|| |1|0|1|0|BIPSDK.InfoStore:query|bowin1pp:7472:101.15969:1|BIPSDK.InfoStore:query|bowin1pp:7472:101.15969:1|cms_BOWIN1PP.CentralManagementServer.queryEx3|localhost:2908:2076.63089:1|CiUpvLiCWk3nlgkFI6z6NO03d82|||||||||||The value of SI_ID should be a number but instead was 4294969658
.\DatabaseSubsystemHelper.cpp:667:-: TraceLog message 809
|57bbc4a1-e6bc-f794-daad-e138a0e2149b|2016 06 21 16:30:18:748|+0200|Error| |  |E| |cms_BOWIN1PP.CentralManagementServer| 2908|2928|| |1|0|1|0|BIPSDK.InfoStore:query|bowin1pp:7472:101.15983:1|BIPSDK.InfoStore:query|bowin1pp:7472:101.15983:1|cms_BOWIN1PP.CentralManagementServer.queryEx3|localhost:2908:2928.63102:1|CiUpvLiCWk3nlgkFI6z6NO03d90|||||||||||The value of SI_ID should be a number but instead was 4294969658
.\DatabaseSubsystemHelper.cpp:667:-: TraceLog message 810
|9a1550f6-c8ce-b664-189e-e0ade814aa47|2016 06 21 16:30:20:092|+0200|Error| |  |E| |cms_BOWIN1PP.CentralManagementServer| 2908|2936|| |1|0|1|0|BIPSDK.InfoStore:query|bowin1pp:7472:101.15988:1|BIPSDK.InfoStore:query|bowin1pp:7472:101.15988:1|cms_BOWIN1PP.CentralManagementServer.queryEx3|localhost:2908:2936.63107:1|CiUpvLiCWk3nlgkFI6z6NO03d95|||||||||||The value of SI_ID should be a number but instead was 4294969658
We don’t understand this line : “The value of SI_ID should be a number but instead was 4294969658” and what we can do to avoid that ?
We thought that this issue could have been solved by a service pack, so we updated from XI4.1 SP06P5 to SP07P5, but there is no change.
When we try a basic Publication, with only one document, and one enterprise recipient, we get this error :
trc file: "jobserver_BOWIN1PP.AdaptiveJobServer_PublicationSchedulingService_CHILD0_ncs.trc", trc level: 1, release: "720"
[Thr 5452] Wed Jun 22 11:52:36 2016
[Thr 5452] ***LOG Q0I=> NiPGetHostByName: '$SMDAgentHost' not found: getaddrinfo [ninti.c 897]
[Thr 5452] *** ERROR => Main agent failed to be initilized due to incorrect host setting! [ncsmtdatasen 20]
[Thr 5452] NCS trace timer is disabled since the interval is set to 0
[Thr 5452] NCS data timer is disabled since the interval is set to 0
[Thr 5452] NCS library version 2.3.12 (unicode) loaded
[Thr 5452] NCS_ProcInit API invoked
[Thr 5452] NCS configuration info begin----------------
[Thr 5452] NCS configuration loaded from file C:/BOBI4/SAP BusinessObjects Enterprise XI 4.0/conf/BOWIN1PP/
[Thr 5452] Current NCS Configuration:
[Thr 5452] _socket_recv_timeout=1000;
[Thr 5452] _socket_send_timeout=500;
[Thr 5452] agent_host=$SMDAgentHost;
[Thr 5452] agent_port=$SMDAgentPort;
[Thr 5452] agent_type=2;
[Thr 5452] auto_transaction_trace_threshold=600;
[Thr 5452] cache_section_count=2;
[Thr 5452] context_map_bucket=13;
[Thr 5452] datasending_interval=0;
[Thr 5452] datasending_method=socket;
[Thr 5452] empty_timeout=300;
[Thr 5452] instrument_level_threshold=0;
[Thr 5452] lib_trace_level=1;
[Thr 5452] logdir=e:/BOBI4/logging/;
[Thr 5452] max_components_per_promotedstack=50;
[Thr 5452] max_components_per_transaction=5000;
[Thr 5452] perf_metric_scope=0;
[Thr 5452] skip_times_below_threshold=500;
[Thr 5452] system_name=SBOP ENTERPRISE\bowin1pp_6400;
[Thr 5452] trace_enabled_via_e2e=1;
[Thr 5452] trace_enabled_via_em=0;
[Thr 5452] trace_preview_timeout=120;
[Thr 5452] tracecheck_interval=0;
[Thr 5452] tracesize_threshold=1000000;
[Thr 5452] zombie_check_interval=300;
[Thr 5452] zombie_timeout=86400;
[Thr 5452] NCS configuration info end----------------
If you have any idea, it would be great, and I’d be very gratefull, because we are really stuck at this point ! :hb: :hb: :hb: [/code]
seb2501 :fr: (BOB member since 2015-05-12)
Hi Seb,
Did you ever get to the bottom of the “The value of SI_ID should be a number but instead was …” messages? Just noticed them on our BI4.1SP7 system when investigating a separate issue. Everything appears to be running fine otherwise.
Last time I checked 4294969324 was a number too. :slight_smile:
DanDensley :uk: (BOB member since 2009-05-12)
