I must install BOXIR2 in two clustering servers to provide fault - tolerance, i.e. if the first one crashes the second one automatically starts. I dont want to provide load - balacing functionality.
I installed everything in S1 (Windows). The database for CMS is Oracle and the schema in oracle is named boxi. Cluster name is the same of the server name (S1)
Now i installed BOXIR2 in another Windows server called S2. In the installation wizard on question Installation type I have to choose one the following choice
- New
- extend
- custom
I chose extend).
I chose the name of the CMS in S2 the same one of the CMS name (S1). Then I installed all server (cache server, job server,…) and then I installed WCA (Tomcat) in S2.
I tried to rename the cluster . I stopped the S1, and in tab Configuration specify button I wrote the new cluster name myCluster.
When I started the CMS, the name is notchanged.
Then I verified: S1 and S2 are started
When i used “S1:6400 …” in system name I opened infoview and when I used “S2:6400 …” in system name I opened infoview.
Then I tried to stop s1 and the servers didnt switched but they stopped.
In This situation When i used “S1:6400 …” in system name I didnt open infoview and when I used “S2:6400 …” in system name I opened infoview.
Then I tried to stop S2 and to start S1
I want that system name is the same (ever) and because the user dont know the server started or stopped.
Can The windows cluster be useful? Wich parameters must I change?
Please help me to solve this problem.
ettore (BOB member since 2006-12-11)
(BOB member since 2004-07-22)
