[XI 3.1] ERROR Couldn't logon to CMS (STU00152)
As the WIPS was not running on BO server I run following commands:
./ccm.sh -stop all -cms myserver:6400 -username Administrator -password zaq1plm
./ccm.sh -start all -cms myserver:6400 -username Administrator -password zaq1plm
After tis I tried to run below given command:
./ccm.sh -display -cms myserver:6400 -username Administrator -password zaq1plm
However I got error as follows:
err: ERROR Couldn’t logon to CMS (STU00152)
err: Error description: The system myserver.com can be contacted, but there is no Central Management Server running at port 6400.
I also tried to enable the server but still received same error message.
I am using Solaris platform so want to know how to start CMS?
jayesh_deshpande (BOB member since 2009-07-21)
Check if the DNS is available and restart the BOXI3.1 servers, being sure that no BO processes are running.
In order to avoid issues related to a downtime of the DNS, insert the hostname resolution of the machine where the CMS DB resides:
Edit the “hosts” file in the /etc directory of the Unix server where BOXI3.1 is installed
Insert the IP address, <hostname.localdomain> , of the machine that is hosting the CMS database
start the BOXI3.1 servers and tomcat (if used)
If BOXI3.1 is configured as a cluster installation, edit and add in the “hosts” file the name resolution of all the nodes that are part of the cluster.
Shane Graser
www.datamanagementgroup.com
“Transforming Data Into Information”
Shane.Graser :us: (BOB member since 2010-06-28)
Thanks for the reply.
I checked “hosts” file. There I found the entry as you specified to do. I again tried to restart BO server however it again showing same error when tried to check the running services through command prompt.
I am really stuck…
:hb:
R u able to solve this issue I am facing the same
manant25 :india: (BOB member since 2005-10-06)
